The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
4 motor airplane
Old 02-07-2016, 02:01 PM
Default 4 motor airplane
Hi I bought a airplane from radio shake last year it was a foamie, it had 4 motors no flight controls the motors made the airplane turn and the speed make it go up or down http://www.dollarhobbyz.com/products...D4MaAmFX8P8HAQ this is how the motor looks when I opened it. It has a 3.7 volt 200 mah battery that gets charged by the remote. I want to take the parts and put it in a light weight guillow airplane the typhoon which is a great glider and fly it. The props are about 1 inch and a half will this work ?
Old 02-07-2016, 03:12 PM
flyinwalenda's Avatar
The Guillow's Typhoon is a WWII single engine plane. http://www.guillow.com/typhoon.aspx
You must be referring to a different model.
Anyway, if the model is light enough I suppose it would work.
Old 02-07-2016, 07:16 PM
I know it's a single engine plane but I am putting 4 motors, I do not want it to be scale
Old 02-07-2016, 07:20 PM
I heard it weighs 26 grams when its built adding the rc equipment about 30 grams in total will it fly ?
Old 02-08-2016, 05:03 AM
Not sure where you are getting your weight specs but a ProtoX weighs 11,5grams rtf.
Will it fly? I don't know. If the Typhoon with the motors,esc/rx,and battery weighs the same or less than the radio shack plane then maybe.
Old 02-11-2016, 09:33 AM
JollyPopper's Avatar
I don't understand. Are you putting four motors on a single engine airplane?
Old 02-11-2016, 04:03 PM
Yes it appears so. I was going to try and discuss it in more detail but figured ,just let him try it ,experiment,and learn .
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
