Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > The Clubhouse
Reload this Page >
What paint to use for EPO foamie ???
The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Old 02-29-2020, 09:30 AM
JohnS
Default What paint to use for EPO foamie ???
I have an FMS Explorer small pattern plane (sold by Horizon). This plane is made of EPO foam. It's colors are hard to see at certain attitudes. Need to get some bright color on the wings. What is a safe spray paint for EPO foam???
Thanks for any info
Old 02-29-2020, 09:43 AM
mkjohnston
Hi Johns, you would need a type of paint that would not harm the phone but an idea just popped into my head. If you have a good Hobby shop in your area you might look there and see if they have Top Flite Monokote trim sheets. I would get one of the neon colors and cut out the shape you need and stick it to your wing. I do this with balsa wood airplanes as it helps to tell if I'm right side up when flying!
Michael Johnston
Old 03-01-2020, 03:22 AM
JohnS
Hi Mike,
Thanks for the reply. I have also used those sheets, and they work very well over a monokote surface. The concern I would have is with their adherence to the foam.
Thanks again,
John
Old 03-01-2020, 08:14 AM
Steve Collins
My Feedback: (8)
You can use any enamel, epoxy or polyurethane paint without worries.
I have used Trim Monokote on foam airplanes and it adheres very well.
Old 03-01-2020, 09:44 PM
Joe Nagy
Wink Another inexpensive foam paint solution
Hi John;
Stop off at your local Walmart, go to the Arts & Crafts section of the store and look for their displays of little 2 oz Acrylic paint bottles, literally dozens of colours, from mild to wild, at less than a buck a bottle. Mix these 50/50 with either water or Windex glass cleaner and use your airbrush. Does not hurt the foam. I purchased a 'dozen pack' for under $10, + a few oddball colors. Try this simple inexpensive solution, you may just like it, best regards from Wickenburg, Arizona,
Joe Nagy.
Old 03-02-2020, 06:33 AM
JohnS
Thank you guys........great ideas, and great help. This is a great community we have here at RCU.. John S
Old 03-02-2020, 05:21 PM
jester_s1
Moderator
EPO isn't bothered at all by standard rattle can spray paint. I have a Parkzone Stryker, also EPO, that I painted with basic hardware store Rustoleum.
Don't try to mask with tape though. The paint doesn't stick well enough to not pull off.
Old 03-03-2020, 03:28 AM
JohnS
Thanks Jester......I just bought some Rustoleum enamel red.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
