2C equivalent
MN
More on Saito FA-.80
Thanks again for your reply. Sincerely Darryl.
Anyone else have an suggestion?
Technically a FA 80 is a 2 cycle engine, not a 4 cycle. It is a 4 stroke engine.
Also, as pointed out above equating 2 stroke and 4 stroke engines does not usually mean using the same props but rather providing the same thrust. Larger volume 4 stroke engines typically turn larger diameter props, or more blades, at a lower RPM. People like them because they "sound more realistic". But do they really? A P-51 Rolls-Merlin V12 turns between 2400 to 3000 RPM. With 6 cylinders firing every revolution that's equivalent to a single cylinder turning 14400 to 18000 RPM. Have you ever seen an FA-82 turn more than 12000 RPM? A decent 60 can turn 16000 to 17000 RPM. I had an OS32SX with a 10x4, 3-bladed prop on a Royal Midi Corsair. It turned 19000 PRM and had more thrust than a 10x6 driven by a Tower 40. But even at 19000 RPM it didn't have the same high pitched scream that the Double Wasp radial Corsairs had.
daveopam (10-06-2020)
