Work bench Table Top
Hi There,Hoping to take advantage of Cyber Monday. I'm considering picking up this electric sit/stand desk frame for my workshop, as I have trouble bending, sitting and standing. I'm not sure what to use as a table top?
https://www.btod.com/btod-vertdesk-v3-base
I heard a tip long ago saying hollow or foam core doors can make cheap, flat, disposable table tops. Maybe something like this but, I would think hollow doors could bow in the middle over time.
https://www.lowes.com/pd/Woodgrain-2...B&gclsrc=aw.ds
I rarely build, but even checking CG or balancing props needs a flat, level surface. I'm getting into larger scale planes so my current table is becoming a bit too small at 30"x60"x1". Any ideas?
And, I'd like to get it with locking castors. I wonder if I would need a way to make small adjustments to the top to level it since it uses two synced motors?
Also could use some advice on any rolling, pneumatic, padded stools?
Thanks, in advance, for your thoughts!
I use a solid core door with Homasote screwed down to the door. Very heavy but makes the table very sturdy. I am 70 in fairly good shape but I need a helping hand to put the top in place. The Homasote holds pins better than anything else I have used. It also works great when wood working as it does not mark or damage surfaces, edges and corners. When the surface gets too damaged just flip it over and use the other side.
flyalan (12-07-2021)
Free Table
If you join Freegle there are always people wanting to give away old(dark Wood) tables, several times I have had really good solid wood table's
You can also get large pieces of kitchen work top
Free Table
I received my bases and I've taken the legs off my current table. I need to figure out a plan to put supporting boards under the desk top. The legs and the motor will be screwed into the supports. I almost posted a pics for suggestions after I learned how expensive wood is now!
But, to save weight and cost, I think I have spare planks I can use and I won't have to go the whole distance of the desk since there are already cross beams for the drawers.
ohnow (01-18-2022)
