The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Wax paper
Old 10-20-2002, 07:27 PM
bliebo
Default Wax paper
What ever happened to wax paper,CA sticks to it like glue,ha ha. Maybe it is the brand and i should go back to Cut Rite.
Old 10-20-2002, 07:29 PM
GrnBrt
GrnBrt's Avatar
Default Wax paper
I bought the cheap store brand and it was a nightmare, went back to cut rite and no real problem. Just make sure you have the more waxed side up.
Old 10-21-2002, 02:32 AM
rryman
rryman's Avatar
Default Wax paper
I've been having trouble even with Cut-Rite. I attributed it to the CA being better than it used to be. I wasn't aware of one side being different than the other. That might be it.
Thanks for the tip GrnBrt,
Randy
Old 10-21-2002, 02:41 AM
TexasAirMedic
Default Wax paper
the only cutrite i can find is about 12 inches wide...any of you found the 18" wide rolls like you can find in aluminum foil ?
Old 10-21-2002, 03:36 AM
GrnBrt
GrnBrt's Avatar
Default Wax paper
Run the paper through your fingers while pinching it and you feel that one side is a bit more slick then the other, usually the side to the roll.
Old 10-21-2002, 09:06 AM
bliebo
Default Wax paper
Thanks for the replys i amoff to the super market.
