Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > The Clubhouse
Reload this Page >
Yet another windex question. .
The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Old 01-19-2008, 02:42 PM
Crash90
My Feedback: (17)
Default Yet another windex question. .
Did a search, came up with lots of info. One answer I did not find. Do you guys usually hit the monokote with heat once the windex has dried?
Old 01-19-2008, 05:43 PM
BUDMAN27
BUDMAN27's Avatar
Default RE: yEY ANOTHER WINDEX QUESTION.
Old 01-19-2008, 06:08 PM
Crash90
My Feedback: (17)
Sorry Bud. Not sure what ? means.
Old 01-19-2008, 07:22 PM
red head
Default RE: Yet another windex question. .
I do !!! ENJOY !!! RED
Old 01-19-2008, 08:01 PM
Live Wire
Live Wire's Avatar
I can not believe these responses[:@]
Old 01-19-2008, 09:41 PM
Rebsix
My Feedback: (8)
Rebsix's Avatar
ORIGINAL: Crash90
I do Crash. After leaving it over night I use an iron on low heat with a sock. I also put a very small touch of thin CA on any corners or points that may peel up later.
Hope it helps.
Old 01-19-2008, 09:59 PM
carrellh
carrellh's Avatar
I tried using heat on the edge and got a bubble. I read about usiing a q-tip dipped in acetone or trim solvent to go around the edges so that's what I did.
Old 01-19-2008, 10:30 PM
Crash90
My Feedback: (17)
Thanks guys.
Old 01-20-2008, 12:14 PM
Deadeye
Deadeye's Avatar
If I do use heat, it is the next day and only on the edges and only on sheeted surfaces. Open bays get the Q-tip dipped in trim solvent.
Old 01-20-2008, 12:59 PM
RCPAUL
I use heat around the edges with a trim iron.
Paul
Old 01-20-2008, 02:40 PM
BUDMAN27
BUDMAN27's Avatar
Sorry I just didn,t understand what you were looking for.
Old 01-21-2008, 08:54 PM
Rebsix
My Feedback: (8)
Rebsix's Avatar
You'll get bubbles if you use too much heat or by using a heat gun. The key is just enough heat to activate the glue while using a sock on the iron.
I use the CA on the tips because every time i realize I need to get some trim solvent, or Acitone It's already too late and I want to finish [:@]
Old 01-22-2008, 07:59 AM
jettstarblue
jettstarblue's Avatar
Guess I'm missing something here...why do you guys need to use a heat gun or iron after using windex?
I've used windex or similar for years and years and never had any covering come up.
Old 01-22-2008, 10:52 AM
daven
I've had corners lift, normally when I have something come to a point (like a star). I've been hittting it with light heat, but you gotta be carefull or it can bubble.
Old 01-22-2008, 06:42 PM
Rebsix
My Feedback: (8)
Rebsix's Avatar
ORIGINAL: jettstarblue
Don't get me wrong, I'm not saying you have to use heat, it's just my personal preference to use it, and he couldn't get a decent answer so I explained the way I do it.
Just don't expect the technique to work with Ultracote. I woke up the next morning to a pile of curled up numbers under my wing [&:]
