The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Sepulveda Basin
Old 08-07-2007, 01:40 AM
  #6401
My Feedback: (15)
Default RE: Sepulveda Basin
Billville, you are a smart man. Alot of truth to what you wrote. I do agree.
As for you Mr. Basinite, I wonder if you would like to express you feelings to me in person. I REALLY would like to meet you. Would you like to meet me?
I'll tell you what, I'll be at the field this Thursday and Sunday. Why don't you come up and introduce yourself to me.
Billy
Old 08-07-2007, 02:05 AM
  #6402
DrV
DrV's Avatar
Hey Basinite
Why don't you come out and let all the other jet guys know how you really feel about jets? Man, you have a lot of nerve with such comments. There is a large turbine community at the basin and it keeps expanding. Like Billy said, introduce yourself to him, he is the Turbine Director for VF. Maybe he can help you resolve some issues.
Old 08-07-2007, 02:22 AM
  #6403
saramos's Avatar
Basinite gets too scared by the big bad jet sounds. Is he the same fellow who wanted to get rid of the CL circles to have an indoor mini electric field, because, after all, those old CL guys are dying off anyway?
Cory,
Did you get any more flights in? Did the gears hold up?
Scott
  #6404
skubacb's Avatar
Which channels did you have remapped to failsafe at a user settings?
Since XPS comes with a failsafe that keeps all channels at current settings if the RX did failsafe nothing at all would have changed. I.E. the turbine would have stayed at full throttle, the gear would have stayed up. Not knowing all about the setup it sure seems like something other than TX failsafe.
I wonder that if the entire RX was ejected from the a/c and everything else burned, how well were the servo/battery leads connected to the RX. So far I have not seen a crash where the RX disconnected every lead. How well was the RX protected by foam?
My score. 350 flights with PCM/PPM - one a/c damaged due to interference. 250 flights with Spektrum - four a/c lost due to loss of TX/RX link. Over 350 flights with XPS - no lost a/c. So far I have flown XPS with everything from foamies, powered sailplanes, to 50cc aerobatics planes. I do find that the placement of the RX is important to get an excellent field check. Also, I have been careful to make sure there are no wires close to the RX which can vibrate. (Both of these items are important for all 2.4ghz systems.)
I consider the first post to be not well researched or documented. I can find cases of a/c crashing on any system in use today. Spektrum has released a fix for its 6 channel rxs. Now they are at revision v1.2. I have read about lost link between the RX and TX on non-XPS systems. Why only hit on one system? Lets ban all systems that have ever crashed an a/c. That post leaves me questioning its intent.
Old 08-07-2007, 02:38 AM
  #6405
My Feedback: (15)
No that was Resedaguy818 . I don't know this basinite guy...but I WILL find out.
Old 08-07-2007, 05:35 AM
  #6406
My Feedback: (51)
5 guys use the XPS system at the basin and 5 have failed at on point or another
need read better 3 of 5 came out said it was they radio (not xps. sys )
jim offer to come out Jason Pakfar said he did wnat him out on weekin
i thanks you guy going be sue by lot of xps guy.for now they have case
i thanks Jason Pakfar let jim come out. see what up
good luck
heli46
Old 08-07-2007, 09:41 AM
  #6407
COULD YOU TYPE LOUDER? I CAN'T UNDERSTAND YOU...
Old 08-07-2007, 10:02 AM
  #6408
saramos's Avatar
Cory,
Here's a couple of photos of the FliteSkin I was telling you about. Also, a couple of shots of the gear doors.
Scott
ID:	737545   Click image for larger version
ID:	737546   Click image for larger version
ID:	737547   Click image for larger version
ID:	737548   Click image for larger version
Old 08-07-2007, 10:26 AM
  #6409
Kriptonic69's Avatar
You know what people, All the club did was not allow XPS at the field for a jet event for lack of the better word "Safety Reasons".
If you guys want to continue this, then go start a new thread somewhere else...... But please don't type here unless you have something to contribute to the BASIN............Gene
Old 08-07-2007, 12:14 PM
  #6410
My Feedback: (162)
jonkoppisch's Avatar
Actually there were quite a few earlier posts in this thread specifically about xps and how it wasn't working at this field. That makes it a part of this thread. But par for the course...
Added:
It's ok to slam xps and post but....
I do fly xps and spektrum. I am fair about it though and slam whoever for what I see that is BS!!!!
Old 08-07-2007, 12:35 PM
  #6411
My Feedback: (15)
ORIGINAL: heli46
good luck
heli46
Old 08-07-2007, 02:26 PM
  #6412
ORIGINAL: heli46
good luck
heli46
Wow, besides the poor Engrish,,, you talk about "i thanks you guy going be sue by lot of xps guy." If someone does bring up a lawsuit about how XPS was not allowed at a field, then bring it,,, cus it would be just like someone sueing over a dog bite when the guy hopped over a fence that had several signs saying "Beware of Dog"...
What it boils down to is the fact that there is a Safety issue and the club decieded to not allow XPS at the Field for the Jet Event unless it can be determined that it can be used safely, (maybe it has to do with the changing in the anntenna design and these failures maybe have been caused by the original anntena systems, but who really knows for sure at this time).
Gene
Old 08-07-2007, 06:52 PM
  #6413
This thread is going nowhere. What inquiring minds want to know is what TRANSMITTER was used with the XPS modules when the crashes happened. I have been following all the XPS threads and it appears to me that he Futaba-XPS combo has the most problems. If XPS is good in JR and Multiplex then it is not XPS's problem it is Futaba !!
Old 08-07-2007, 07:07 PM
  #6414
ORIGINAL: Parkerm
Well, not really.
Futaba radios have been out for some time now.....
Perhaps there is a compatibility problem with XPS and Futaba, but I sincerely doubt it is directly the fault of Futaba.
Old 08-07-2007, 07:14 PM
  #6415
My Feedback: (162)
The only issue that I've heard of is with the 9z.
Old 08-07-2007, 08:29 PM
  #6416
My Feedback: (90)
TLH101's Avatar
Jim Drew has reported, in the Rc Groups thread, that he and Jason have connected, and have worked out an arrangement for Jim to
"bring our spectrum analyzers with us so we can determine the level of noise (on all frequencies, not just 2.4GHz) and record a few hours worth of data for analysis."
http://www.rcgroups.com/forums/showt...=8#post7947493
Old 08-07-2007, 10:05 PM
  #6417
Well, not really.
[/quote]
New technology often brings to light unknown issues with older technology. Could be that the sensitivity of the XPS system exposes a flaw that was not obvious in lower frequencies. Because XPS is module based the fault could well lie inside the transmitter.
I'm just suggesting that to find the root cause that the fishbone diagram should made and expanded to include transmitter brands and models. What works well with one brand and model may have an issue with another brand and model. To determine whether the cause is XPS or a particular transmitter, design, firmware or pot these things must be known.
Anyone reporting a crash should include this information, and any personal mods to the transmitter so that the community can draw the diagram.
Without this kind of research the community will forever be divided.
Old 08-08-2007, 12:41 AM
  #6418
My Feedback: (15)
Yes this is true TLH101, Tonight we discussed with some of the board members the issues that we have been talking about here on the SB thread. It is nice to know that Jason and Mr. Drew have made contact and have agreed on a date for the testing of the XPS system here at the basin. As we are concerned to find out the truth of the XPS system here at the basin, we are confident that Mr. Drew will also want to make sure, if in fact there are any issues, that the XPS system is solid here at the basin. It is a win win situation for EVERYONE to get to the bottom of this. Just like the field in LAS Vegas, if there are problems I'm sure they will be reconized and dealt with, if there are no issues then we can all fly with confidence.
I would like to say at this time that since this arguement has started( some time ago) we have all heard the different sides to the issues at hand more than once. I am sure the re****s of the testing will be posted and we can all come to our own conclusions. It would be nice for the BASIN thread to get back to some sort of normalicy. So lets all hang tight and relax and go into this with a clean slate. After all this is about SAFTEY, and we may be one step closer to some closure on this.
Just my feelings,
Billy
P.S. Except for you MR. Basinite, I'm still looking to meet you.
Old 08-08-2007, 01:36 AM
  #6419
My Feedback: (24)
Kmot's Avatar
Let's hope the rhetoric from the XPS proponents, about shutting down Apollo Field altogether, ends as well. That was the most arrogant and irresponsible diatribe of all. [:@]
Old 08-08-2007, 01:43 AM
  #6420
Well said Billy.......
Gene
Old 08-08-2007, 12:25 PM
  #6421
My Feedback: (23)
Jason or Billy.......
Could you post here or at least pm me when Jim drew is coming to the field. I have been reading all the threads on xtreme link since the beginning and am very curious about it.
thanks...Ron
Old 08-08-2007, 11:20 PM
  #6422
Jackjet's Avatar
sounds like you have a bad case of turbine envy.................
jackjet[]
Old 08-09-2007, 12:30 AM
  #6423
My Feedback: (8)
scale dail's Avatar
Scale Masters next weekend!
Old 08-09-2007, 12:48 AM
  #6424
My Feedback: (18)
GoeKeli's Avatar
Corey,
PLEEEEASE Get this plane in the air and fly it at scale masters!!!!
What will you be flying? I hung with Brad the other day and his Newport is top notch and looks like he is ready.
Joe
ORIGINAL: scale dail
Old 08-09-2007, 01:23 AM
  #6425
My Feedback: (24)
Kmot's Avatar
Is that Corey's Thud?
Hey Corey, send me some stuff for the newsletter!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
