Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Epoxy
Old 07-15-2014, 07:24 AM
RAPPTOR
My Feedback: (41)
Default Epoxy
Looking for best surfacing epoxy.. Z poxy ok but gets soft in sun. West system is a mixing nightmare.. Help??
Old 07-19-2014, 11:58 AM
wyowindworks
What about mixing West Systems is a nightmare?
Old 07-19-2014, 12:08 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Exactly, Im wondering how the Zpoxy was mixed and cured that leads to such a low TG.
Old 07-19-2014, 01:39 PM
RAPPTOR
My Feedback: (41)
Ratio of-- 3.72 / 1--- on extra slow hardner
Old 07-19-2014, 01:41 PM
RAPPTOR
My Feedback: (41)
As per spec.. 50-/50/--- maybe tad less hardener as instructed
Old 07-19-2014, 05:56 PM
invertmast
My Feedback: (23)
invertmast's Avatar
Two words..
ratio pumps
Old 07-20-2014, 06:43 AM
Pylonracr
Pylonracr's Avatar
I use a gram scale for small amounts.
Old 07-20-2014, 08:14 AM
speedracerntrixie
My Feedback: (29)
Two most important keys to epoxy resins, correct mix ratio, keep above 70 degrees. An epoxy that gets soft in the sun tells quite a lot. First it may not have been mixed at the correct ratio, it may have cured at too low of a temp or being in FL the humidity could have played a part. No matter the cause the result was an incomplete crosslink. Getting soft in the sun would actually be performing a somewhat uncontrolled post cure and after a few cycles the epoxy would cure a bit better.
Old 07-21-2014, 03:48 AM
sensei
sensei's Avatar
Bob
Old 07-21-2014, 08:05 AM
MTK
Try CJ Composites or US Composites. Both offer inexpensive laminating epoxies (not finishing, so they might need a thorough sanding and cleaning to hold paint). Working time is about 30 minutes.
Old 07-21-2014, 09:51 AM
RAPPTOR
My Feedback: (41)
OK
Old 07-22-2014, 04:41 AM
sensei
sensei's Avatar
Mix ratios are simplified with use of a digital scale and calculator.
For a 3.72:1 ratio just equate 100 divided by 3.72, this gives you a 100/26.882 Resin/Hardener mixing ratio, so as an example lets' say you have poured yourself a 185 gram mass of resin into a tarred cup sitting on the scale, just take 185 X 1. 26882 and you have 234.73, or simply 235, now pour your hardener in the cup with the resin until you get to a 235 total gram mass, resin and hardener combined, mix and use.
By adding the 1 in the front of the 26882 you have included the resin mass to the equation, it is that simple and works with any epoxy resin systems or mixing ratios and is as accurate as a ratio pump.
Bob
Old 07-23-2014, 02:31 AM
RAPPTOR
My Feedback: (41)
WAY COOL. BUT MY COMMON MIX IS AROUND, 5 TO 15 GRAMS RESIN. CALLED- WEST.. SAID 3.5 TO 3.9 CLOSE ENOUGH.. I THINK THATS FOR MUCH LARGER BATCH MIXES.. THANKS FOR INFO.. I NEED GRAM SCALE THATS MEASURES LESS THAN 1 GRAM.. sorry for caps,, old habbit
Old 07-23-2014, 03:09 AM
sensei
sensei's Avatar
The calculation for mixing mass ratios is the same for a 5 gram mass,15 gram mass, 5000 gram mass or whatever, it doesn't matter, what does matter is the smaller your mass is, the more accurate you must be in your shop practices to achieve a proper cure, and you are mixing the smallest mass I have ever heard of, so that makes me very interested and brings me to a question if I may ask; what are you applying a surfacing resin too that would use only 5 grams of resin? Just curious...
Bob
Old 07-24-2014, 03:17 AM
RAPPTOR
My Feedback: (41)
Thanks for info.. Yes small mix is very easy to mess up.. Must clean container poured from.. I mix small amounts for .75 .oz cloth.. To do say 1 foot square.. Or renforcing.. Areas
Old 08-02-2014, 09:59 AM
T_om
After a LOT of research and experimentation I now use Adtech 820 resin and hardener.
Go here: http://www.adtechplastics.com/pc-64-...ng-system.aspx
It is VERY low viscosity, very good properties re: cure, hardness, etc. even without hot boxing it... performs even better at slightly elevated temperatures. I use the 824 slow hardener. And unlike Pro-set very slow hardners (and some others), the 824 does not incur Haz-Mat charges.
Nothing wrong with WEST and I have a bunch of it left over from full size boatbuilding. But the 820 handles SO much beter for small parts that I use it for all modeling stuff now with the exceptions of making molds.
Tom
PS: The price ordered directly from Adtech is actually lower than retail dealers prices. Shipping is not bad either.
Tom
Old 08-03-2014, 04:10 AM
RAPPTOR
My Feedback: (41)
thanks
Old 08-03-2014, 04:23 PM
rt3232
Just my 2 pennies worth.
Good Gram scale can be had from Harbor Fright, and I might add that it makes 1/1 mixes easy, also keep a cheep hand calculator handy make the math easy for any ratio mix. Have never had problems with any epoxy except Z-Poxy seams humidity is a big factor.
Cheers
