Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Paint run
Old 04-28-2020, 04:26 PM
My Feedback: (27)
7aso's Avatar
Default Paint run
I have some minor paint run to the undercarriage. What is the best way to fix this.
Old 04-28-2020, 05:22 PM
The fix for this is actually quite simple!
Make up a sanding block that's about 1"x 2", tightly wrap some #600 wet sandpaper around it, wet the sandpaper by dipping it in some water and gently sand the run until smooth while keeping the sandpaper wet. A drop or two of soap or dishwashing liquid can be added to the water for better lubrication.
After the surface is sufficiently level and smooth, repaint the part, being careful not to cause a run this time!
Old 04-29-2020, 12:22 AM
My Feedback: (27)
7aso's Avatar
Thanks I'll give it a try
Old 04-29-2020, 01:27 PM
Actually, the 'best" way to fix that run is to very carefully watch the part after you paint it for runs. If you see one forming, turn the part in the opposite direction of the run and let it run back. Many times the run will disappear. It sounds like i'm joking but i've had to do this a lot more times than I care to admit. It works.
So next time, catch them while they're wet. This time, what the other guy just said.
carl
Old 05-02-2020, 04:11 PM
My Feedback: (27)
7aso's Avatar
It worked out great. Paint run gone. Thanks for your help.
Now I have a new problem:
What's the best way to fix the paint peel? Sand it off and start over or fill it in
Old 05-02-2020, 06:28 PM
Whether to sand and/or fill it depends on how dry or hadened the paint is. If the paint is rubbery it won't sand very willingly and chances are that the edges of the paint will continue to peel.
It would certainly help to know what kind of paint it is, but I have an idea anyway.
With a very sharp blade, carefully trim away all peeled away paint. Take a fine point artist brush and fill in the peeled area with the yellow making sure that the paint being brushed is making complete contact with the surrounding paint edges. Let it dry thoroughly and wet sand over the affected area in the same fashion as done for the run to make it smooth again and follow up with a finish spray coat of paint to complete the job.
The reason for painting with a brush first is to seal the edges where the paint peeled so that the layer of paint will not continue to peel during sanding and the brushed paint also provides at least some amount of filling in the peeled area before sanding.
Brushing paint onto the bare spot may not be absolutely necessary before sanding, but it provides a little extra assurance that sanding will not cause further peeling.
Old 05-03-2020, 01:32 AM
My Feedback: (27)
7aso's Avatar
Thanks. I'll give it a shot today.
I'm using warbird colors. For some reason, yellow is the only color that peeled on me.
Old 05-03-2020, 06:13 AM
My Feedback: (29)
speedracerntrixie's Avatar
What material is the yellow paint applied to and how did you prep?
Old 05-03-2020, 07:38 AM
My Feedback: (27)
7aso's Avatar
Fiberglassed fuse with filler primer, stripped down then added primer from warbird colors. painted over with a numax gravity feed gun. I mixed and thinned with water per instructions and applied evenly.
Old 05-03-2020, 08:00 AM
My Feedback: (29)
Did you sand the Warbird brand primer at all before applying the yellow? Just trying to figure out your lack of adhesion issue.
Old 05-03-2020, 01:30 PM
My Feedback: (27)
7aso's Avatar
So far so good. The trick worked. Maybe I didn't mix it well enough?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
