Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Mold Considerations
Old 03-27-2004, 05:23 PM
Default Mold Considerations
Mold Considerations
I have my plug all made up for the cowling of a small Piper. It is sanded and sealed to shape, and up front it has a prop shaft hole and two irregular shaped ovals for engine cooling all cut in. I am planning on using standard fiberglass cloth and polyester resin for making the finished parts.
Question is about the mold.
Just about at set up time, it is customary to trim off the excess fiberglass hanging over the edges of the mold. In planning the mold, I want to be able to cut out the cooling and prop shaft holes also while trimming off the excess. My thought is to carve along an edge down in the cavity of the mold which underlies at the three holes up front.
The mold has not been made yet, but should I set in outward aimed plugs to the three holes such that they will create depressions in the mold which I can cut against.
Or, is there a better way yet?
I do not want to carve out three holes in the hardened fiberglass cowling the next day.
Wm.
Old 03-27-2004, 05:42 PM
Default RE: Mold Considerations
The way I handle these inlets and shaft outlets is to put only the minum amount of glass and resin in those areas. Usually just the gelcoat and one layer of glass. All the rest is done with the usual multiple layers of glass and resin. When you pull the part from the mold you will see that the "thin" areas are quite weak. Just cut them out (I use a Stanley knife) and then sand the edges smooth. That way you don't have to use your Dremel and a carbide tip to clear the unwanted lay-up out of the part. Regards.
Old 03-27-2004, 07:10 PM
I don't even own a Dremel tool/set. However, would it be fair to state then to do the standard gel coat lay up.
Then when it comes time to go further in the process, at the inlet area just put on lightweight cloth and resin. Blend in heavier weight (or multiple layered) material onto the sides and resin blend in.
I am still a bit shady as to how the holes would then be prominent enough to cut out. I still need a bump or hollow in the mold where these inlets are, correct?
Wm.
Old 03-28-2004, 01:41 AM
Mike James's Avatar
Here's how I prepare holes in plugs for molding...
I don't try to do a lighter layup in the area of the holes. I just mold the whole thing, then cut the openings.
Old 04-03-2004, 08:57 AM
dreadnaut's Avatar
ORIGINAL: CoosBayLumber
I would highly recomend getting a dremel, or similar tool. I would go crazy without mine.
Old 04-05-2004, 09:23 PM
I haven't used a Dremel in years. Too delicate looking. Have a small air powered die grinder which gets used on occasion, and uses cheaper and easily available tooling.
I have a 2HP milling machine in the garage which seems to get the light cuts done accurately and quickly for me. Also can use a 7HP or a 15HP powered mill just down the street. Got more power than I need at present time.
Wm.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
