Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Reload this Page >
f22 raptor-rc work on progress!
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 09-07-2007, 11:38 AM
  #126
hpghost
hpghost's Avatar
Default RE: f22 raptor-rc work on progress!
little more...
I found an issue with top of outlet,,had to break it!
ID:	758377   Click image for larger version
ID:	758378   Click image for larger version
Old 09-07-2007, 06:08 PM
  #127
Mods-R-Me
Mods-R-Me's Avatar
I applaud your effort. Your stab and rudder came out beautifully. Sanding/preparing a plug is a PITA (I know from experience). Would it be possible to separate the fuse in four sections in CAD and cut them out with the CNC machine as well?
Love your work,
Mods
Old 09-07-2007, 11:28 PM
  #128
hpghost
hpghost's Avatar
yes it is also possible to do the fuse with cnc and if I didn t already done it I would have used this solution (which was my primary idea).
however it would be very long.
Old 09-08-2007, 12:17 AM
  #129
hpghost
hpghost's Avatar
here is a simulation of the cnc milling of the bottom side of the wing...as you can see there are some panel lines directly milled for easy placement!
Old 09-08-2007, 04:04 AM
  #130
hpghost
hpghost's Avatar
the molds under progress + a simple tool for perfect symetry I have just made.
ID:	758817   Click image for larger version
ID:	758818   Click image for larger version
ID:	758819   Click image for larger version
Old 09-08-2007, 06:08 AM
  #131
RVM
Do you think you might have this finished by winter?
Old 09-08-2007, 07:45 AM
  #132
hpghost
hpghost's Avatar
well...no, I do not think as it is not full time occupation.
I have a very time consuming job and also doing lots of other activities!
lets say that just to build the wings molds I calculated about 50hrs job (40 milling + 10 sanding/finishing/laminating). and I need at least 10 hrs strait shift for the milling so le's say it needs holidays lol
Old 09-09-2007, 10:49 AM
  #133
hpghost
hpghost's Avatar
here is the mold of the stab. it is now finished!
I had few issues...first had to cut out its shape as it didn t wanted to come out after molding and then one one of them I damaged badly the primer coating of the master.
anyway this can be fixed and hopfully I do not need them before quite some time (in any case I can mill it again and get 100% same result).
I also attached the progress on the airframe.
that's all for next 2 weeks as I will not have more time to work on that...
ID:	759553   Click image for larger version
ID:	759554   Click image for larger version
Old 09-18-2007, 11:35 AM
  #134
hpghost
hpghost's Avatar
I found out that the noze was not strait compare to body (gluing problem I think) so I cut and rectified with the help of the laser...
now the model is perfectly strait!
ID:	765511   Click image for larger version
ID:	765512   Click image for larger version
ID:	765513   Click image for larger version
Old 09-18-2007, 11:41 AM
  #135
bruce88123
Now is the time to find it.
Old 09-18-2007, 11:42 AM
  #136
hpghost
hpghost's Avatar
yeah! that's why I double checked now
Old 09-21-2007, 09:37 AM
  #137
hpghost
hpghost's Avatar
here is the result of some 3D work to simulate the shape of the vectorized nozzle.
I made a prototype with paper before trying with stainless steel!
I also tried a decals paper I got on ebay...looks working pretty good!
ID:	767075   Click image for larger version
ID:	767076   Click image for larger version
ID:	767077   Click image for larger version
Old 09-24-2007, 06:56 PM
  #138
chevypower1930
AMAZING, I HOPE I am one day as talented as you building planes...
Old 10-05-2007, 02:53 PM
  #139
hpghost
hpghost's Avatar
today I did a short video clip of the simulated vectorized nozzles! have a look on my website!
[link]http://www.raptor-rc.com/rcraptor/index.htm[/link]
Old 10-05-2007, 03:58 PM
  #140
bruce88123
ORIGINAL: hpghost
What kind of file is that? I can't open it.
Never mind - got it open. Interesting.
Old 10-06-2007, 12:31 AM
  #141
hpghost
hpghost's Avatar
it is a DIVX video format (uses less kbps)
Old 10-06-2007, 01:04 AM
  #142
hpghost
hpghost's Avatar
2 pics of the inlets consuctruction start...
ID:	777286   Click image for larger version
Old 10-10-2007, 11:51 PM
  #143
RVM
Will you be selling this as a kit?
Old 10-11-2007, 04:35 AM
  #144
hpghost
hpghost's Avatar
well,
if it works well and I think that quality is high enough maybe yes.
at present time I am not focusing on that aspect, I am mainly focusing on how to make it as best as possible.
in order to sell it has a kit, it would require some molds modification compare to what I am going to have so that it could be reproduced without too much difficulties.
also it would mainly depends on demands.
but again...FIRST I WANT IT TO FLY, THEN ONLY WILL START TO THINK OF NEXT STEP!
Old 10-12-2007, 09:19 AM
  #145
hpghost
hpghost's Avatar
again a new video...this time it is the real test of trust nozzle!
see my website!
[link]http://www.raptor-rc.com/rcraptor/videos/nozzle%20divx%20test.avi[/link]
Old 10-22-2007, 11:43 AM
  #146
hpghost
hpghost's Avatar
AFTER FEW WEEKS WITHOUT PROGRESS HERE IS THE LATEST PROGRESS:
i JUST FINISHED 3D MILLING OF THE 1ST RUDDER (WITH PANEL LINES DONE BY CNC MACHINE), i ALREADY STARTED THE WINGS AND MIGHT SEND PICTURES SOON!
Old 10-23-2007, 11:44 AM
  #147
hpghost
hpghost's Avatar
here are the roughing pics of the 1st half of 1st wing... so far looking good
ID:	788794   Click image for larger version
Old 10-24-2007, 09:11 AM
  #148
hpghost
hpghost's Avatar
at last after 10hrs of machining the 1st half wing is done...with panel lines of course!
ID:	789514   Click image for larger version
ID:	789515   Click image for larger version
Old 10-24-2007, 10:09 AM
  #149
bruce88123
Looking good. Don't you ever go to work?
Old 10-24-2007, 11:31 AM
  #150
hpghost
hpghost's Avatar
that's beauty of holidays! you don t need [8D]
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
