Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
heat shield ceramic
Old 03-08-2007, 10:38 AM
hpghost
hpghost's Avatar
Default heat shield ceramic
hi,
again some technical question...
Which technique would you propose for the following:
the exaust nozzles made of composite material orientate the turbine 600deg hot air from the SS exaust pipe.
does ceramic paint thick layer will protect enough the parts from long exposure?
what alternative solution do I have?
Old 03-09-2007, 01:45 AM
davidfee
Default RE: heat shield ceramic
Use stainless steel for the exhaust ducting.
Old 03-09-2007, 02:45 AM
hpghost
hpghost's Avatar
the exhaust ducting is already Stainless steel as mentioned. it is the vectorised F22 nozzles which are made of composites and needs to be protected
Old 03-09-2007, 10:32 AM
davidfee
What is the temperature of the exhaust gas at the location of the vectoring vanes?
Old 03-09-2007, 11:29 AM
Ed Smith
Some more details would help.
The composite vanes would be a stiff material not flexible when finished, Right?
Why cannot the whole assembly be stainless steel?
Ed S
Old 03-09-2007, 03:34 PM
hpghost
hpghost's Avatar
here is a picture top explain what I mean
Old 03-09-2007, 05:20 PM
Ed Smith
Sorry, I canot offer help, beyond my sphere of knowledge.
Ed S
Old 03-09-2007, 05:22 PM
davidfee
You need to define the temperatures before you can start looking for materials.
Old 03-09-2007, 05:27 PM
davidfee
My point is, if the EGT is 600F at the point of the vectoring vanes, epoxy/fabric composites will not be suitable. Ceramic sheets may work fine, if you can find them. You need air between your "heat shield" and any composite structure. Stainless still looks like the easiest solution.
Old 03-10-2007, 03:07 AM
hpghost
hpghost's Avatar
hi,
here is a schematic of the pb.
and below a link of products I found interesting...
http://www.cotronics.com
Old 03-18-2007, 11:36 PM
hpghost
hpghost's Avatar
does BVM heat shield will do?
