Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Seal Balsa before applying epoxy ? >
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 05-27-2003, 05:08 PM
Default Seal Balsa before applying epoxy ?
Originally posted by Darrinc
2. Bake your balsa for 3 hrs at 200F to drive off any moisture.
(moisture is the # 1 reason for laminate failures)
Is there any associated wood shrinkage or warp with this procedure? I guess I could try a test piece to get some results.
The reason I ask is I have already constructed the 1/16 balsa laminate for the foam cores on my current project. There are some tricky spots where the grain runs perpendicular in some places, is shaped as triangles, etc. I'm wondering if it is too late to cook?
TX-Deck
Old 06-07-2003, 08:01 PM
Sounds like another Dam whitch is better more weigth and stength. Or less weigth and less strength. DAM if you do dam
if you don't. But the old shellac is good but a bit brittle Dam. CU
Old 04-30-2004, 01:59 PM
My Feedback: (34)
Default RE: Seal Balsa before applying epoxy ?
Aquanet hairspray. Light dusting is all you need.
Old 05-01-2004, 03:06 AM
Wet out peel ply, lay on balsa, vacuum bag. When cured, it will leave a very light, bondable skin.
Simple, effective.
Old 05-01-2004, 11:39 AM
Did you miss a stage, like, peel off the peel ply?
Ed S
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
