Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
 Help figuring out freezer compressor >
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 06-03-2007, 07:25 AM
Default Help figuring out freezer compressor
Hi fellas:
I pulled this compressor off of an old freezer. I wired up the plug, but compressor didn't run. Electrical stuff is really not my forte and I thought I'd see if anyone can tell from the pictures below what needs to go where before I wind up running 220v through myself ha ha.
ID:	696396   Click image for larger version
ID:	696397   Click image for larger version
Old 06-03-2007, 07:48 AM
Default RE: Help figuring out freezer compressor
It would have had a thermostat somewhere which opened and closed the circuit (Simple switch) Find where the thermostat was and join those wires. Until you do this the pump won't run. It was something I have found most "how to's" don't address.
Without seeing the pump in person and only going from your pics those two black wires should be joined up and the pump "should" run.
Old 06-03-2007, 09:47 AM
yes, the two black wires were hooked up to a dial-type thermostat. I connected them but no result. There are two power cords coming from the unit. One went to the plug for the main power, and one went to a fan unit hooked to a radiator. I have now mixed the two of them up. I thought perhaps I had the wrong one, so moved the plug to the other one, but still no result -- not even lots of smoke. Maybe the whole thing is bad, but I have been told that it was replaced prior to storage and that it is pretty unused.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
