Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Reload this Page >
epoxy/fiberglass nitro tank
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 06-04-2007, 07:29 PM
kelly vallee
Default epoxy/fiberglass nitro tank
I would like to know if I make a fiberglass tank with epoxy resin, will it resist the nitro? I know it works with kero.
Old 06-04-2007, 09:43 PM
AlW
My Feedback: (17)
AlW's Avatar
Default RE: epoxy/fiberglass nitro tank
I think that you will be OK with nitro on epoxy resin. We raced Formula 1 airplanes for years using fuel containing up to 60% nitro which oftentimes got inside the epoxy resin glass fuselages and it did not seem to hurt anything except make an oily mess. You could do a simple test- mix up a little resin and put it in some nitro or whatever fuel you intend to use.
Good Luck,
Al Watson
Old 06-04-2007, 10:26 PM
dclancey
Nope won't work. The alcohol will soften the epoxy and make it a gooey mess. You will need vinyl ester resin to make a fuel tank. Been there done that!
Old 06-05-2007, 06:02 AM
Ed Smith
My experience is as dclancey describes except I had an epoxy fuselage go soft.
Ed S
Old 07-07-2007, 11:22 PM
freakingfast
Kwik Poly is not the answer ether. I built a tank out of epoxy glass and coated the inside of it with Kwik Poly. Pour it in and slosh it around and when it sets up in about 5 minutes I put it in to an oven to cure at 150*. It looked as hard as a rock. First day it worked fine. It was fuel totally drained after that. Two days later after the first flight of the day the engine quit due to low fuel pressure ( a compromised tank) I had to quickly tear off the Ultra coat to get the fuel out of everywhere. The whole fuel tank was like a gob of salt water taffy. I think this stuff is a Polyurethane.
