Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Reload this Page >
Vacuum forming questions
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 07-13-2007, 08:25 AM
Campy
Campy's Avatar
Default Vacuum forming questions
I am going to try my hand at vacuum forming. I have built a 10" x 12" x 3" box and a 750 watt hot plate in a reflective foil lined box for a heater and I have a 10 gallon shop vac for the suction (bag and filter removed for this).
Everything I have read has indicated that PETG is what to use for the canopy.
The canopy questions are:
The canopy will be about 2 1/2" wide x 3" high x 3 1/2" long.
What Thickness PETG would you suggest ? I have .030, .040 and .060 thick PETG, or do I need something thicker.
I have the plug already carved from balsa. Will regular balsa be OK to use or do I need to harden it with something, if so what ? Trying to carve the plug from pine would be extremely difficult considering the raised framework and rivet heads.
Can I also use the PETG for the wheel pants ? If not, what would you suggest using, and again, what thickness ?
Each half of the wheel pant is 7" long x 3 1/2" wide and (with the 1/2" backing ) 1 1/4" thick. The wheel pants are made from pine.
Old 07-13-2007, 09:42 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Default RE: Vacuum forming questions
Generally, the harder the wood, the better.
ID:	722014   Click image for larger version
ID:	722015   Click image for larger version
Old 07-13-2007, 10:54 PM
Deadstik
My Feedback: (8)
Deadstik's Avatar
Sean,
Great Looking plug !!! Could you give me an idea of what type wood you used to make the plug along with the tools that you used to shape it? I usually do a balsa fuselage,and then glass it for a plug.. but I'd like to try it the way you have done it. Thanks,
Dan
Carolina Custom Aircraft
Old 07-13-2007, 11:32 PM
seanreit
My Feedback: (60)
seanreit's Avatar
That was made by a CNC machine, I was given the molds to bring the airplane to fruition, which as you can see, I've done. I don't know what specific type of wood the plug was made from, but it is a very very hard wood. Do a search for "eddie weeks" on google and go to the corpcomp site.
