Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Reload this Page >
What do i need and where can i get it
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 07-13-2007, 12:52 PM
Flying freak
Default What do i need and where can i get it
Hi
I want to add some fiber glass to the inside of my great planes viper to reenforce some areas like the wing hold down and the firewall what do i need what "size" figer glass and would standered 30 min emoxy be ok or??
im clueless as to what i need i understand the how to apply it just not sure what to apply [:-]
Thank you
Steven
Old 07-13-2007, 01:10 PM
TeamSeacats
TeamSeacats's Avatar
Default RE: What do i need and where can i get it
3 to 5oz fiberglass will do nicely. You can use the 30 minute epoxies, but my experience is that they don't harden as well as a true laminating epoxy.
Old 07-13-2007, 10:58 PM
Deadstik
My Feedback: (8)
Deadstik's Avatar
Steven,
I'll have to go with 6 oz cloth and at least one hour pot life epoxy. I've found simply that the shorter the working life, the less strength the fiberglass will have. The laminating epoxy that Jake is talking about that at least 12 hours (or longer) to completely cure. Just remember that more epoxy does NOT mean a stronger joint... what you are looking for is simply to wet out the cloth, not make puddles in it.
good luck with your project..
Dan
Carolina Custom Aircraft
Old 07-14-2007, 01:57 AM
Aquila223
Go with lighter cloth and more layers. One layer of 6 oz cloth is the same in weight as 2 layers of 3 oz cloth or 3 layers of 2 oz cloth BUT the more layers of cloth you use the stronger the part will be. You can get them all wet and applied at the same time, just put the first layer in and wet it out then stick the second layer on top and wet it out continue until you have all layers in and wetted out. It wil go transparent when wet and this shows you any dryspots.
Old 07-17-2007, 10:49 AM
cadmn
the more layers the more crossed fibers hence strength resin alone is brittle the fibers give it strength. I like Matt instead of cloth
Old 07-18-2007, 12:12 AM
Aquila223
Mat, cloth, same thing. My point was use lighter cloth and more layers of it.
Old 07-20-2007, 09:23 PM
cadmn
sorry but I must dissagree Matt & cloth are TOTALLY different being from that industry. Cloth is like a silk material where the threads are woven togather in a pattern. Matt is fibers bound togather in every which way Like in chop. never seen matt outside of industry, always cloth in LHS.
Old 07-20-2007, 10:25 PM
Aquila223
I was using the term in the broader sense of being fabric. Go be pedantic elsewhere.
