Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Wing Repair
Old 07-23-2007, 06:01 PM
wetsu82
Default Wing Repair
Guys or girls, I need help, damaged my wing, tear on right front of wing. everything good now exept the balsa covering over repaired skeletal frame. The problem I am not sure how to fix is how do I bend a piece of balsa on the curved part of the wing on the front between the top and the bottom of the wing. Everytime I try to curve the wood around, it breaks in half. Please help? Thanks R Sparks
Old 07-23-2007, 06:09 PM
BeanerECMO
BeanerECMO's Avatar
Default RE: Wing Repair
Did you wet it thoroughly before bending it around the skeleton contour?
Old 07-23-2007, 08:45 PM
wetsu82
Nope, I thought that was the solution but I wasn't sure. How do I glue it if it is wet? Thanks...Have to have it ready to fly by Saturday.....Thanks for the help.
Old 07-23-2007, 09:40 PM
BeanerECMO
BeanerECMO's Avatar
I’d suggest just using water to soak the wood before bending, pin down the wood, and then have the patience to let it dry before gluing.
Old 07-24-2007, 06:16 AM
propbuster
propbuster's Avatar
I've found that using Windex with ammonia works great for wetting out balsa to conform to a tight radius. Like Beaner said, pin or tape the piece in place, let dry, then glue it up.
Old 07-24-2007, 07:49 AM
BeanerECMO
BeanerECMO's Avatar
If the area is hidden; i.e., no clear covering, that mixture is ok as ammonia tends to turn CA milky. Use plane water if it is going to be exposed.
Old 07-24-2007, 09:31 AM
propbuster
propbuster's Avatar
Yup, Beaner is correct on that. Sorry, I didn't even think that the covering might be transparent
Old 07-24-2007, 11:30 AM
wetsu82
Thanks guys it is fixed, replace the covering and ready to go....
