Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Cut Fiberglass Cowl?
Old 06-17-2008, 01:01 PM
My Feedback: (36)
Default Cut Fiberglass Cowl?
What tool should I use to cut fiberglass cowl for the P-51?
Old 06-17-2008, 01:39 PM
Default RE: Cut Fiberglass Cowl?
I start with a reinforced cutting wheel on my dremel to cut a rough hole in the cowel, then use a 1/4" drum sanding bit to smooth it out.
Old 06-17-2008, 02:18 PM
yup...what he said
Old 06-17-2008, 03:14 PM
TeamSeacats's Avatar
ORIGINAL: rcfunhouse
Carbide or Diamond cutting wheel for the dremel (cuts like BUTTER!)...then touch up with with a flapper sanding wheel on the dremel.
Old 06-17-2008, 03:37 PM
use a torch to heat an #11 Xacto blade and it'll cut it like butter and there won't be any dusty mess.
Old 06-17-2008, 05:54 PM
combatpigg's Avatar
To make perfectly round holes, use a cone shaped grinding stone mounted on either a die grinder or drill motor
Old 06-17-2008, 09:33 PM
My Feedback: (36)
Thanks so much. I have a dremel with Diamond cutting wheel, also have torch and #11 Xacto blade...so I am going to try both ways and will let you know.
Thanks again
Old 07-03-2008, 11:04 PM
My Feedback: (36)
ORIGINAL: KC36330
Hi guys, I used the gas stove to heat up the xacto blade and it cut it like cut FROZEN butter, have to heat up the blade over and over and over but it beat the dusty mess when used the diamond cut blade with the dremmel.
I used the dremmel with the grinding fine stone to clean up the openings. It turned out very nice
THANKS EVERYONE.
Old 07-04-2008, 10:26 PM
As for all that dust, I took a center island table I had in my shop, cut out the center, reinforced it, and mounted peg board to the surface. I then boxed in the underside of the top and sealed it. With a hole in the side of the table, I can connect my shop vacuum and with it on it draws a good bit of air down through the peg board and into the vacuum. If I'm remotely careful about the direction the cutting tool throws the dust, the table/vacuum collects it all.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
