Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Mold questions
Old 01-01-2009, 01:48 PM
Randy Etken
My Feedback: (10)
Randy Etken's Avatar
Default Mold questions
What do you use for indexing pins to alien your molds? I have been using marbles and wanted to know if there is something different and where do you buy? Also when I join the two mold halves, I hold them together with 8-32 machine screws with wing nuts. Is there something to replace the wing nuts that would be permanent? Just curious what others use.
ID:	1100774   Click image for larger version
Old 01-01-2009, 02:02 PM
ByLoudDesign
ByLoudDesign's Avatar
Default RE: Mold questions
First with the molds screwed together, usually before you pull it from the plug, I would drill a I have drill a #7 hole through both flanges, at least 3 places. Seperated the mold halves, pull out the plug and tape the bottom mold flange for a 1/4-20 fastener. Drill out the top half of the mold to 1/4". Now using a full threaded hex BOLT screw them up through the flange and glass in the head. Pretty much a perfect fit everytime.
Charlie
Old 01-01-2009, 06:45 PM
SCALECRAFT
My Feedback: (13)
SCALECRAFT's Avatar
What has worked for us are 1/2 spheres of various shapes purchased from craft stores. Note pick something that you won't have a difficult time cleaning the female side when waxing and using.
Steve
Old 01-06-2009, 08:19 PM
AllanU
AllanU's Avatar
What I used were the self adhesive rubber/plastic door bumpers like the ones on the inside of your kitchen cabinet doors so they so not bang when closed. The come in all sizes and shapes, hemi-sperical, round-flat, square, etc.
Place them onto the parting board and remove them after you mold the first half. Wax and PVA the hole and lay the other half of the mold. The alignment is tight. In fact the 2 halves snap together.
Al
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
