System 3 Epoxy
1 Attachment(s)
Hi Guys,
I'm using the System 3 Epoxy and light fiberglass cloth on a N.P. P-38. It is the first time using epoxy and class cloth on a model and I was able to get some good advice on line through RCU on how to do this. I used to use fiberglass resin and cloth...but I managed to get a real bad reaction using this. I used playing cards to wipe and squeegy the excess epoxy and it worked great. I'm now finishing the pilot pod for my P-38, then eventually do the whole model the same. Has anyone any tips you can give me...: ) Soft Landings Always, Bobby of Maui |
RE: System 3 Epoxy
Were you using gloves?
I get rashes on my hands if I do not.. |
RE: System 3 Epoxy
After I get the cloth saturated with resin I take a paper towel and blot the excess resin off. This makes the finish sanding much less time consuming and reduces weight.
