Epoxy Fillers in Modeler Friendly Sizes
All of the StegallHobbies.com epoxy fillers have free shipping to the 48 continental US excluding destinations with high shipping costs like military bases. We are working on expanding to Canada and Mexico on Amazon and the products will soon be available on a new StegallHobbies.com web site for other international customers and those who do not buy from Amazon.
If you need epoxy fillers for this building season, make sure you check out http://EpoxyFillers.Store We recently added 3 more filler types in 4 ounce and 8 ounce sizes. Milled Fiberglass Epoxy Filler - http://amzn.to/2AqL7Pd Milled Fiberglass is sometimes referred to as liquid fiberglass. It makes a jelly like paste depending on ratio of epoxy used. Mix it with Cab-o-sil (silica) or Micro Fibers to form a non-sagging paste. Excellent for bonding wood, fiberglass, carbon fiber, and composite materials, especially in corners where a fillet can be made. It is not good for fairing where sanding is needed as it is extremely hard. 1/4" Chopped Carbon Fiber Epoxy Filler - http://amzn.to/2jIBlQD Chopped carbon fiber is great for reinforcing firewalls and nose areas where appearance doesn't matter. But smooth it out with a brush and if possible use a grinder or flapper wheel to knock off the sharp points. Wood Flour Epoxy Filler - http://amzn.to/2icQVDy Wood Flour Epoxy Filler is excellent for fixing dings and miss-drilled holes in hardwoods like plywood, oak, maple, etc. It is light brown in color to match natural wood. It sands well, but is heavier than other fairing fillers. Thickens to a non-sagging past with the proper ratio of epoxy. |
We're definitely not the only game in town.
But we are striving to produce products that R/C modelers and other hobbyists will find useful and convenient. Our Sampler Kit has the four fillers that anybody that works with balsa, plywood, foam need to enjoy building or repairing. See https://www.amazon.com/Epoxy-Filler-...StegallHobbies for the 4 ounce size. And https://www.amazon.com/Epoxy-Filler-...StegallHobbies for the 8 ounce size. The Completer Starter Kit is going on Amazon this weekend. It adds 4 more kinds of fillers combined the the ones in the Sampler. |
