Composite wing lay up examples
I’m about to build a composite wing and I would be grateful for some advice before I start. I have a decent amount of experience from working with composite materials, but this is the first time I’m building a full composite wing.
My main question is what laminate to use for the wings (glass cloth thichness, sandwich material etc) and also how to build the spars If I build the wing of a sandwich lay up what material is suitable? If I build the wing of a single skin (no sandwich) then what material thickness is suitable (I’m interested in hearing examples of both types of lay-up) ? When gluing the upper and lower halves together what is the best way to glue the leading edge? Wing spars and trailing edge is easily glued with an epoxy microballoon mix, but in the leading edge the fibers meet tangential. What is the preferred way of doing this strong and light? I have seen that some put in a list of balsa wood, but that seems kind of weak. The wing will be moulded in negative moulds, is 2m span, and is designed for a jet aircraft. I intend to use balsawood as sandwich material and I will use only fibreglass for the skin (while spars will be carbon reinforced).The aspect ratio is comparatively high and the thickness is quite small. For this reason I think similar lay-ups as used on high performance gliders would be suitable. Is there any web pages that has some docomentation on different lay-ups as used in different projects? I have done some googeling for pages of glider builders but without any thrilling result. Or are there perhaps any other threads here on RCU that might be helpful? I spent yesterday evening reading though many of the threads here but could not get all my answers. /David |
RE: Composite wing lay up examples
I think here is perfect thread for sandwich planes.. u need to do registeration but its worth it!!
http://www.warbirdforum.de/forum/thr...569d72e122098a and use this if language is too difficult!! im using it all the time... http://translation2.paralink.com/ and in this german forum is soooo many composite plane projects! cheers Jukka |
ORIGINAL: Grumpy1940 http://www.scalewings.com/welcomepage.php here is his site and lot of production pictures! |
Thank you for the great links [sm=thumbup.gif]
After some research I also found these superb web pages. They answered most of my remaining questions. http://video.google.com/videoplay?do...62&q=f5b&hl=en http://www.gliders.dk/moulding.htm /David |
http://www.r-g.de/en/downloads.html
here you find all aplication guide and designing manuals for composite model airplanes. its perfect! cheers |
| All times are GMT -8. The time now is 04:21 PM. |
