Converting RC engines to Control Line
OR
Kiwi
you are correct today I would buy a OS 40 LA and make a venturi out of a plastic spacer and run it.
But the problem is that the guy that has my engine has a fancy web page and runs a popular C/L forum has set on my engine for over 12 months with out even having the courtesy of sending me one email explaining the delay. When he does answer my emails it's my fault that he does not have the time to work on it.
Shouldn't be a problem. Just offer to pay postage to have it returned to you. Remember, some of the engine reworkers are also avid contest guys.
For the LA, why not get the CL version and you won't have to mess with the spacer.
George
George
Fox Lovers:
Ill admit it. My sameful secret. I used to fly Fox engines. They were the old four-bolted head 0.35 engines. Those of you who remember them probably also remember carrying a supply of head gaskets, and a Phillips screwdriver to change them.
Flip the prop a few times and hear a loud pop, change the head gasket and flip it some more. When you got it started it ran fine, with an excellent 4-2-4 break. But that head gasket...
Then I discovered Johnny Brodbeck, and it was "Green Head" K&B for me.
Granted, Ol' Duke did fix his problem when he finally went to the six-screw head, and did away with the paper gasket on the head. Too late. I stayed with K&B.
I did buy another Fox every once in a while, and I found that while the head gasket problem was corrected, another weak point showed up. And granted, they didn't break the rod, the new weakness was the crankshaft.
The attached picture is the bottom of the crankcase of one Fox I've kept, to remind me not to buy another.
Bill.
Bill.
#31
OK, so you discount my experience, you never heard of me in CLPA circles. How about Bill Werwage? Remember the Ares series of planes? Right. That Bill Werwage. He got tired of having Foxes blow up, and was instrumental in getting Hi Johnson to start building engines. He did finally give up, and just tolerated the regular engine changes staying with Fox.
This picture is the guts of the same Fox shown in tha last picture.
Bill.
Bill.
#32
Odd:
My father loved them. He had 29,35,36x,40bb and a 59. Either ran good ole 5% Superfuel, Missle Mist, or his last favorite, Duke's Mixture. Never had any trouble out of his engines. I've flown Fox, K&B Torpedo and McCoys (yes the infamous 'Red Head 35).
Never had trouble with any of them and we flew the hell out of them almost every Sunday.
Later:
littlefly
Later:
littlefly
#33
AL
[That Bill Werwage. He got tired of having Foxes blow up, and was instrumental in getting Hi Johnson to start building engines. He did finally give up, and just tolerated the regular engine changes staying with Fox.]
Actually Hi Johnson was already in the engine business at the time. Bill worked with Johnson to build a better stunt engine than Fox but they were unsuccessful and Fox dominated PA until the trend to larger engines.
I used some Johnsons in Combat untill the Fox Combat Specials came along. The Johnsons were very nice engines and Hi was a super guy.
#34
Jessie:
You're right. I should have said Bill W. got Hi Johnson to start building stunt engines. But I got the unsuccessful part right.
Bill.
Bill.
#36
AL
A friend with a Johnson powered Nobler once did a perfect wingover except for no pull out. The 90 degree, one point landing on concrete of naturally shattered the engine like a tea cup. As a joke my friend sent the pieces of the engine to Johnson with a letter explaining that while he was admiring his new Johnson he accidentaly dropped it on the carpet. A few days later a New Johnson 35 came in the mail with a handwritten note from Hi Johnson congratulating my friend on his creativity!
#37
The first one of that type I owned is the one I just picked up off eBay with a Series 75 Torp as well, for pocket change. But many of the older guys at the flying fields in the early 1950's used the old Fox, and none of them had problems with head gaskets, or at least none complained where I heard about it. By the time my paper route was big enough and profitable enough to buy NEW engines, the Fox had already moved to a six bolt head (mid-1952 was about when that change occurred, I think).
The 1952 Torps were still made with natural-colored heads, and they LOOKED GOOD. The Foxes, most that I've seen, have almost always been rather ugly looking. I bought a used K&B 29 in 1951; that was my first glow engine. I bought a new one of the same model the following year. I saw the Fox in the display case. Compared to the K&B, it was very homely looking, but it DID have:
1. Trumpet flared intake
2. Six head screws
3. Smoother exterior than the so-called "Sandcast" predecessors
4. Name Fox, and displacement size raised disk on the bypass.
Those aspects defined the change from the prior model, and there were a few Fox engine heads made with a lot more screw holes, probably 10, so the same heads fit both the 4-bolt, and the 6- bolt cases. Watch the very interesting video tape about the entire family of Fox 35/36 engines; all the changes are shown with examples of each.
I also didn't get around to owning a Rocket 35 until many years after it was replaced by the Blue Ribbon 35X. The second run of Rockets were the Foxes with a lower end looking like a Testors McCoy (as in the image mentioned). The first Fox that had consistent crank problems that I became aware of was the 1974 36X Combat Special {or "Mark II", or "Baldie"}. I owned several of those during 1975/1985 and used them in AMA Slow Combat, with 9" props. They would turn too many rpm's with an 8" prop and spit the front end of the shaft out, very much the way the first G21-35's had done in 1962 or so.
The first six-bolt "barn door" Fox engine had crank problems as well. One of the possible sources of the term "Mark III" used for that engine is that there were two early types of cranks with inferior hardening processing. Duke may have meant that the "I" & "II" type cranks were phased out. He never had used the terms Mark I and/or Mark II, himself, and never told me what the numbering was about for certain. I did ask him personally.
(in Edit: PS: I have a clear recollection of the earliest Fox 29/35 appearance from prior to 1952 (could've been 1953, but probably not that late), and the tremendous improvement represented by the later model, particularly the casting process, which made the Fox appearance somewhat less crude (particularly comparing Fox 35's, though still not as good-looking as the K&B products).
[8D]
Kiwi
ORIGINAL: William Robison
Fox Lovers:
I'll admit it. My sameful secret. I used to fly Fox engines. They were the old four-bolted head 0.35 engines. Those of you who remember them probably also remember carrying a supply of head gaskets, and a Phillips screwdriver to change them.
Fox Lovers:
2. Six head screws
[8D]
Kiwi
#38
Kiwi:
Your time line is a bit off - in 1952 the Foxes were four-screw. The six-screw heads came along around 1958, I think. I got my first green K&B around 1955.
Bill.
Bill.
#40
OK, OK, I broke out a Fox box and read their brochure, "Happiness Is A Fox Motor". They started making the .35 stunt in 1948 and the current model is nearly a copy of the 1951 version.
George
George
#41
My Feedback: (16)
I bought a new Fox 35 stunt in late 1958 and it had the reinforced head bolt bosses in between the fins that the previous model that every one else was using did not have.
Both versions had 6 head bolts. The older version must have been around for a while as there were a lot of them around?
Enjoy,
Jim
Enjoy,
Jim
#42
Well,
I'm remembering four screw heads as being the weak head gaskets, and I know I was still popping them in 1955.
Maybe it was a change after going to the six screw head that stopped the "Heads-a-popping." Perhaps it was at the same time Jim's reinforced bosses were added.
Bill.
Bill.
#43
AL
I have a .29 and a couple of .35s with the 6 bolt head but no bosses so the change was not at the same time.
An upcoming issue of the Engine Collectors Journal is supposed to feature a history of the Fox engines.
#44
My Feedback: (10)
Guys, according to Anderson's BB the Fox 35 started using a 6 bolt head in 52'.
My first engine was a K&B .29S stunt. Given to me in the late 70's by my mentor and I still run it today.
I am 33 so I am afraid I wasnt around when it was actually produced.
Andrew Coholic
PS. this thread, regarding converting RC engines to CL.... I have been an avid hobby machinist for quite a few years. I have converted many, many engines to CL - just make friends with someone who owns a lathe. Its so simple, the venturi, spraybar and needle can be made up in an hour. Never rely on anyone else again!
Get a small hobby lathe...
Andrew Coholic
#45
from what I was told, 52 was non sandcast, 6 bolts, 3 backplate, no reinforcements no crank webbing. 53 had webbings 55-56 had webbings, re-inforcements and somewhere next they added the bar in the exhaust. And that's about all I know other than all mine snarl better than yours on 10% less nitro.
