Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
 My latest little ball of cl fun >
Control Lines For all you fly-by-wire fanatics!
Old 12-14-2007, 01:22 PM
Wayne C's Avatar
Default My latest little ball of cl fun
Golden Hawk from Blackhawk models and my favorite Cox reedy. (pilot, passenger, and wood prop for pictures -- figures removed and prop changed for flight)
Old 12-14-2007, 01:32 PM
Default RE: My latest little ball of cl fun
Cool!
But if it was me, I would leave the pilot and passanger for flight and ensure they each had a silk scarf to help keep warm.
Are they Ping Pong balls are dressed up ?
cheers, Graham in cold and snow Ottawa, Canada
Old 12-14-2007, 02:49 PM
Wayne C's Avatar
The people came in the kit. They were some kind of turned wood. Heavy for they're size. I'm sure the plane would fly with them, but I was trying to save weight in hopes of better loops. I fly the plane on 42' braided spiderwire lines. I tried 35' first, but the lap times were way to fast for me. Loops are better on the longer lines also. More room for maneuvering I guess.
Old 12-15-2007, 06:21 PM
skaliwag's Avatar
I find 42' just right for 1/2A C/L also. What test spider wire do you use?
Old 12-15-2007, 06:44 PM
Wayne C's Avatar
Currently I'm using spiderwire stealth braided. Without running out and checking the package, I believe its 20lb test/8lb diameter.
Old 12-17-2007, 02:39 PM
Nice Plane !!. What kind of covering did you use ? Heat shrink or paint ?
Good flights.
Claudio
Old 12-18-2007, 05:49 AM
Wayne C's Avatar
Bear in mind that the Golden Hawk is a Musciano designed sheet wing hollow log. The only parts that need paint are balsa. I used rustoleum brushed on -- not the rattle can kind. Rustoleum is good paint but heavy so you have to be careful to not over do it. It also needs to cure for around two weeks before it comes in contact with glow fuel. Some people use dope or dope and tissue for a slicker finish. I suppose monocoat or similar would do well but I personally have no experience with it.
Old 12-18-2007, 09:15 AM
Thanks for the information. I´m building and flying small control line models now. Regards
Claudio
Old 12-19-2007, 12:08 AM
ORIGINAL: cortacesped
Good flights.
Claudio
May I suggest "Micafilm" it is currently available in only two colors, translucent red and yellow. Micaflim is 1/2 the weight of Monocoat, and you need to paint the surface you are going to stick it too with "Balsarite", as Micafilm as no adhesive on it. I try to keep the weight of my 1/2 A "stuff" as low as possible. The Micafilm is very strong, and has a little of the look of "Silk Span".
Also great info about the control lines you are using, I'm still working off my VERY old 42' "Pylon" #8 wires. I was wondering what I would use next.
Ralph
Old 12-19-2007, 12:53 PM
gcb
Ralph,
Steel cables of .008x42' are still available. They can be purchased through SIG, Brodak, or any of the online hobby shops that carry CL stuff. Have you tried your LHS?
Many who fly the more powerful modern 1/2A engines prefer .012x42' lines.
George
Old 12-27-2007, 10:18 AM
lukesp's Avatar
I am still waiting on my Scientific log plans from Walt Musciano. He is currently putting the finishing touches to his Corsair book so I need to be patient. He was kind enough to send me a postcard informing he had to finish the book first, very obliging of the man.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
