Control Lines For all you fly-by-wire fanatics!
silk span needed
Old 05-18-2008, 06:49 PM
Default silk span needed
does any 1 here know were a guy could pick up some silk span I live in a small town and we dont have much for stores
thanks for any help on locating some would a Auto parts store carry this
John
Old 05-18-2008, 09:33 PM
Mooney_driver's Avatar
Default RE: silk span needed
Tower Hobby has the K&S brand in 4 weights
http://www3.towerhobbies.com/cgi-bin...EARCH=silkspan
also Brodak sells Silkspan:
http://www.brodak.com/shop.php?CategoryID=151
Hope that helps
Old 05-18-2008, 09:49 PM
There used to be a good hobby shop in Cedar falls.
and SIG in montezuma is a quick phone call away
Old 05-19-2008, 12:01 PM
gcb
John,
If this is for the Corsair, make sure you apply it with nitrate or non-taughtening butyrate dope. Silkspan applied with normal butyrate dope will shrink and twist the light structure like a pretzel.
You should be using a light weight grade of silkspan, and make sure you apply it span-wise. Ask about this after you get the silkspan.
George
Old 05-19-2008, 05:59 PM
Try Peck Polymers, Micro-X, Campbells Custom Kits, FAI supplies. Penn Valley Hobbies. Lots of sources out there for tissue, silkspan, silk, maybe even bannana oil
Old 05-19-2008, 11:14 PM
gcb
ORIGINAL: Jim Thomerson
What, no condenser paper?
George
Old 05-20-2008, 08:44 AM
Don't forget castor oil to use as a plasticizer for the butyrate or nitrate dope.
Banana oil! Wow, Jim, you must be a really old guy.
Old 05-20-2008, 11:14 AM
Actually, some of those sources have condenser paper. My son flew some Easy B and so we had condenser paper. Used it to cover stabs on 1/2A FF models. Dope will not go through it; used thinner to stick it to doped surfaces then doped over the outside. Didn't need much dope to seal.
Old 05-20-2008, 05:25 PM
build light's Avatar
These days its getting easier to find condenser paper than carbon paper!
As for the banana oil, I quit using that stuff long ago because it made it so hard to hold on to the bananas... Now I can hang on to them till there is nuttin but the peel to discard!
Sams Stuff has Silkspan
http://store.sshobbies.com/dopeproducts.html
here are a couple of sites to read up on applying silkspan
http://winshiprc.tripod.com/covering...y_jim_ryan.htm
http://webpages.charter.net/rcfu/Hel...s/SSCover.html
Of particular interest is this link showing a 1/2A model being covered in steps with lots of great pictures!
http://www.aeromaniacs.com/Silkspan/
Have fun!
Robert
Old 05-20-2008, 06:00 PM
gcb
ORIGINAL: build light
Have fun!
Robert
Don't remember ever running across a banana that squeaked!
Bought some condenser paper a few years ago while getting some Japanese tissue. So far, haven't used it. Some day...
George
Old 05-20-2008, 10:38 PM
ORIGINAL: gcb
Have fun!
Robert
George
I never knew any of mine to squeek but when oiled up good and proper they shore did glisten! What a shine they had! Why they'd plain light up the room.
Just the same I went back to the regular banannas 'cuz they were just plaind and simple. Functional you might say.
Robert
Old 05-21-2008, 03:12 PM
Nice links - thanks, Robert.
andrew
Old 06-14-2008, 07:39 AM
Ivanhoe's Avatar
Banana oil is still available, you can even get it on eBay! Never understood the name, it's got nothing to do with bananas, or oil!
Old 06-15-2008, 09:50 AM
gcb
ORIGINAL: Ivanhoe
Smell!
George
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
