Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
 Sterling S30 Beginners Ringmaster Plans >
Control Lines For all you fly-by-wire fanatics!
Old 01-27-2009, 08:10 PM
Default Sterling S30 Beginners Ringmaster Plans
Help!
I'm looking for a set of plans for a Biggners Ringmaster. Any help
would be appreciated.
Jim
Old 01-27-2009, 09:26 PM
Default RE: Sterling S30 Beginners Ringmaster Plans
Check (Google) out Barry Baxter he may have plans . Also, post your question on www.brotherhoodofthering.info (you will have to register) which is devoted to Ringmasters. That should get you a set of plans.
Good luck,
John
Old 01-27-2009, 11:05 PM
build light's Avatar
Good luck on this!
I would like them as well but as far as I know thete were no plans for this plane. As with many of the simple half A plane kits you had hardware, shaped and diecut balsa parts and a set of building instructions. Some of these showed the plane in full size in profile or from a top view showing the wing assembly but most often not all parts were shown full size. They just had pictures or drawings showing when and where to put the pieces.
I am betting the ins. for the Beginner's Ringmaster showed only the fuselage in full size and the wing and outline of the elevator and stab will not be shown in full size.
Robert
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
