RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   SIG Spitfire's (https://www.rcuniverse.com/forum/control-lines-231/10118156-sig-spitfires.html)
skaliwag 11-05-2010 11:34 PM
SIG Spitfire's
Did SIG have a bigger C/L Spit than the 18" job with the molded plastic fuselage?
stuntflyr 11-06-2010 12:00 AM
RE: SIG Spitfire's
Yes,
It was a re-engineered Berkeley 3/4" to 1' kit with great decals. I suppose it's about 28 inches or so.
Do you have a lead on a plastic fuselage 18 incher?
Chris...
skaliwag 11-06-2010 02:07 AM
RE: SIG Spitfire's
Chris. I have one of the 18inch kits. It's a Kwik Bilt, # KBCL1. I sure would like to get a bigger one. Is the Berkeley re-do a profile or built up?
cutaway 11-06-2010 09:09 AM
RE: SIG Spitfire's
35 years ago I had one that was pretty close to scale with a fuselage you planked with little strips of balsa that had curves milled into them kinda like T&G planking. I think that was a Sig kit of some sort.
BtnFlyGuy 11-06-2010 12:39 PM
RE: SIG Spitfire's
I have the Berkely/Sig kit still in the box. 27-1/2" inch span for .09 to .35. It would probably be real nice with a .15. Ihave an Enya .10 that I'm going to use for it if I ever get around to it.
It's a pretty plane with the bead and cove strip planking. Should be a real looker when done.
cutaway 11-06-2010 06:49 PM
RE: SIG Spitfire's
That's the one I had. I remember the box.
skaliwag 11-07-2010 12:03 PM
RE: SIG Spitfire's
Is the lager kit's plan a comprehensive Berkely style or the abbreviated SIG offering?
Were these the only two, or was the a slightly lager version more like the Sterling kit?
stuntflyr 11-07-2010 01:45 PM
RE: SIG Spitfire's
In 1988 I happened across the Sig P-40 and Spitfire plastic full fuselage kits in an old hobby shop. I had enough dough to buy the Skylark stunter and left the little kits behind. I have NEVER seen other examples of either again!
Chris...
BtnFlyGuy 11-07-2010 01:57 PM
RE: SIG Spitfire's
Dont ya just hate that? I've been going back and buying all the stuff Ipassed up as a kid. I almost have enough to start my own hobby shop!
stuntflyr 11-07-2010 02:18 PM
RE: SIG Spitfire's
ORIGINAL: skaliwag
Skaliwag,
Sig bought some of the kits that Fox had bought out from Berkeley. They re-engineered them and I understand they are pretty nice. As far as the plans, I have a friend that has all of the series, I'll check it out when I get back to St. Louis in two weeks.
There are several different designs in the series, T-6, Focke Wulf, Bearcat, Spitfire, and maybe a couple more. They are all 3/4" to 1'. They are Scale models, designed to be used in C/L Scale. There is no other Sig Spitfire that I have ever seen.
Sterling made a 52 inch Spitfire stunter that was a semi-scale stunt model.
Top Flite made a 42 inch Hurricane semi-scale stunter.
Chris...
stuntflyr 11-07-2010 02:34 PM
RE: SIG Spitfire's
ORIGINAL: BtnFlyGuy
Dont ya just hate that? I've been going back and buying all the stuff I passed up as a kid. I almost have enough to start my own hobby shop!
Yeah, I know!
Chris...
BtnFlyGuy 11-07-2010 04:21 PM
RE: SIG Spitfire's
You can handle the flying models and I'll work the plastic scale side of the shop.
