.049 Engine
I currently fly a Brodak .049 engine (which runs very well), but I am curious if there are other companies out there manufacturing .049 engines??
Bjfrankl |
RE: .049 Engine
RE: .049 Engine
There are a number of other manufacturers making .049's like [link=http://www.flycontrolline.com/Profi%20049%20.8cc.htm]this[/link] one but they're mainly all very high performance engines. Just about all of them are made in Russia and turn in the 30,000+ range. [link=http://www.gregorie.org/freeflight/f1j/]This[/link] page has a list of just about all engines in the .049/.061 range.
RE: .049 Engine
Just noticed this thread and thought I should mention that Brodak engines are pretty much a CS engine. I heard they will not be making any more castings after the existing ones are used up. They also made a BB .049 and .06 ABC motor as well. It needed a lot of attention to tolerances and stuff but was pretty good. I have a piped one and a normal one, they were about $100 for the piped quite one a while ago. If I needed a 1/2 A motor I would just get the AP Hornet .09 (or .15 which is the same weight and bolt pattern.) They are ball bearing, ABC, super cheap and a good motor considering. They have a throttle and restrictive muffler though. I made a venturi and needle valve for control line for mine. It goes pretty good with the bigger venturi. For $35 it beats a Surestart and is way better for RC. You can't compete in 1/2 A events though. Otherwise, a Profi or Fora is pretty great!!!$
RE: .049 Engine
I believe the MkII Brodak .049s are made in the Ukraine now. If you wish to play
with diesel engines, the PAW .049s are also currently available; from Carlson engine imports and Eric Clutton. I have a PAW .049 diesel that pulls a Ringmaster Jr on 45' lines and it will do the entire stunt pattern at 54 mph. Tony |
| All times are GMT -8. The time now is 06:00 PM. |
