RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   wanting plans for a small spad c/l (https://www.rcuniverse.com/forum/control-lines-231/11316206-wanting-plans-small-spad-c-l.html)
rayzer 13 12-01-2012 04:04 PM
Well I'm wanting to get back to c/l flying but I keep pusting up my birds anyone have plans for a small spad type plane that can do good loops and figure 8's, ya I know walk befor ya run but what the heck if is tough enough its only gona cost props[>:]
BtnFlyGuy 12-01-2012 04:12 PM
RE: wanting plans for a small spad c/l
Ebay just listed a SIG Control Line Spad for .19 -.35 engines. (No it's not mine!) I've read that they are sturdy as all get out and will do the basic manuvers, but glide like a brick when the engine quits. Good luck with the bipe idea! Justin
aspeed 12-01-2012 05:28 PM
1 Attachment(s)
I made a couple to try getting back into the inverted flying after a couple decades off. The TD .049 does fairly big manouvers, but the .15 sized one is ok, but not as tight loops as the real Yuvenko F2D it was traced from. I put a carbon fiber leading edge on the one Iused. Not the spar like the picture.There is also a Man Win trainer from the Balsa Beavers website that uses a Babe Bee. I doubt it stunts well. The .049 one has a wire going through the flute for stiffening. You can pick your own dimensions and experiment. I put in a pic of a 40 year old Spad Guillows kit I made as a kid.
mikeainia 12-01-2012 05:30 PM
ORIGINAL: rayzer 13
I suspect that by "spad type", you mean something made of sign board or corrogated plastic that can be crashed without too much damage. If so, then you should check out the 'ManWin trainer" on the Balsa Beavers website - this link is to their Man Win page - the plans link is at the bottom of that page.
http://www.balsabeavers.com/newcomers/manwin/manwin.htm
The plans show 18 degrees of engine offset, which is a bit more than you need if you have any experience at all, but you can always take out offset as you get more and more comfortable. You can pound this thing into the (soft) ground all weekend, and not hurt it.
It will do basic maneuvers and inverted flight.
BtnFlyGuy 12-01-2012 05:53 PM
DOH!!!!!!!!!!!! When ya said "Spad." I thought "Spad biplane". Iforgot all about the crash and bash variety. Just shows how out of the loop I've been. I'm just getting back into U/C after a couple of decades off. I'm doing it the old way with Ringmasters and Shoestrings. I'm just happy that super glue and epoxy has replaced Ambroid and double coat glue joints. Welcome back tothe fold!
Justin
icerinkdad 12-01-2012 09:10 PM
Actually the Manwin trainer with a good black widdow will do all the round manuvers pretty well. With two of them you can even fly combat and not worry about breaking a plane. Lots of fun. We have worn out several Cox engines on the same plane flying them.
Have fun! Oh, just google manwin trainer and you should be able to find it.
Bob
aspeed 12-01-2012 09:16 PM
My .049 one was bulletproof.  The .15 one broke the CF leading edge and tank on an inverted fullspeed hit, but was otherwise ok.  They are both fairly fast.
