Electric conversion.
I have a Star Wars Y fighter control line kit for .049 power I would like to build it as electric.
What would be a good motor battery combo for that? How do you safely plug in the battery without the motor starting? Any other advice would be helpful. Thank you. |
This motor will work great.
https://hobbyking.com/en_us/ax-1806n-2100kv-brushless-micro-motor-19g.html?fbclid=IwAR2cVgyUINj5LnOEJMfjQeqjwY9r4LBx JM6teK2OpLuA7jeUcTW7Xyr3ukA This esc https://hobbyking.com/en_us/hobbykin...c-1a-ubec.html I prefer a rc unit for control. A timer is cheaper, but if a problem occurs in flight....well its a problem. With the rc unit I can control when the motor runs. This unit is fine for a 1/2a. If the lines get longer than 42' there can be transmitting problems. You will have to run a rubber band over the transmitter to keep the trigger in full reverse location. Otherwise the trigger goes to "neutral" which is actually half throttle. https://www.banggood.com/Excellway-2...r_warehouse=CN |
Thank you for your reply.
This is a BIG help. Again thank you. |
thanks bob
