RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   Planes for TD .09 (https://www.rcuniverse.com/forum/control-lines-231/4648123-planes-td-09-a.html)
bogateer 08-20-2006 08:55 PM
Planes for TD .09
Sorry...this is similar to my earlier thread. In fit of pique I purchased a TD .09. It was cool and my intentions were pure...I was going to make a twin. The twin really didn't work out to be suitable so now I have this TD .09 looking cool on my shelf. What planes are out there suitable for an .09? It seems they range .09 to .15 and everyone recommends the .15. Are there any good ones for the .09?
Rob
gcb 08-20-2006 10:30 PM
RE: Planes for TD .09
Sure, the Jr. Flite Streak, Ringmaster Jr., Flying Clown, and Akromaster would work. You may find the Flying Clown and Ringmaster Jr a bit fast. The Jr. Lightnin Streak you mentioned on the other thread should be good also.
As mentioned before, the TD .09 is a powerful engine for the size. The planes above that recommend a .15 were designed around .15's that have about the same power as the TD .09. In some cases the modern .15 is a bit big for these, although they can be flown faster using a higher wing loading.
George
