RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   Anyone have plans for the Sterling Beginner Ringmaster bipe? (https://www.rcuniverse.com/forum/control-lines-231/5552085-anyone-have-plans-sterling-beginner-ringmaster-bipe.html)
build light 03-12-2007 08:24 PM
1 Attachment(s)
I am hoping someone here may have the dimensions traced for the sheet parts of the Sterling Ringmaster bipe. I doubt that the building instructions included the actual sheet parts in full size. I do not know this for sure as the only Sterling planes I had were built up wings and of course had to have the full size plans.
Robert
NEW222 03-12-2007 10:25 PM
RE: Anyone have plans for the Sterling Beginner Ringmaster bipe?
Hi there. I do not have that particular plane or templates, but I do however have teh Sterling/Estes reproduction low wing trainer traced out. The tail feathers look the same and so does the wing on the bottom. With these i think you may be able to get the rest right if you would like. Now cleaning up 'the model room' and will find them in the next day or so if you would like something to get a start to. If not, good luck in your search. These are for an .049 as what yours looks like.
NEW222
build light 03-12-2007 10:52 PM
As for myself that sounds close enough to me. I think I could cobble up the rest so that it has the right flavor! The elipses are what would be the most difficult and you just may have solved the problem!
Robert
gordon98 03-14-2007 07:53 PM
hi robert.
i have the full size plans for the sterling kit s-32.beginners ringmaster bipe plane. wingsspan is
20 3/4 in.an uses a 049 eng.i dont know if this is what your looking for but it looks like the pic.if i could fined a way to have the plans copyed i would be glad to send them to you.
hope this helps.
gordon
gordon98 03-16-2007 05:42 PM
hi again robert.
well i tryed to copy the plans for you but the copyers are to small. i folded the plans to try to get them on four sheets then tape togather but i still cant get them all on.so all i can do for you is send the templat,s if i know wher to send them.
gordon
