Rascal stunt plane are ready :)
1 Attachment(s)
I has builded the Rascal stuntplane with ASP 12 + APC 7x4 propeller. The plan of rascal are from Tony Elmore own web site, but there was difficult to read the text and measre then i got copy of the bigger size of plan. A lot of thanks to Tony.
I has a question about centre of gravity in the C/L stunt plane. My plane are nose heavy, CG are near leading edge at main wing. I saw at the CG are located at the plan. Planning to adding weight in end of tail, but will it be heav plane and to be bad stunt plane? What is normal CG for the C/L stunt planes, not sure 25-30% as other planes, may be less than 25%? |
RE: Rascal stunt plane are ready :)
Hi Jens, the Rascal looks great, well done.
Go here for a good C/L trimming and general info site. http://aeromaniacs.com/Benchtrim.htm |
ORIGINAL: vauxhall Go here for a good C/L trimming and general info site. http://aeromaniacs.com/Benchtrim.htm |
| All times are GMT -8. The time now is 10:17 AM. |
