RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   will it fly? (https://www.rcuniverse.com/forum/control-lines-231/6446123-will-fly.html)
p51drb 10-03-2007 06:44 PM
will it fly?
i have got a extra big mig .074 thinking of using it on a sig buster.what do you'll think?will dacron or spiderwire be ok?thanks ahead of time!
Lou Crane 10-03-2007 07:11 PM
RE: will it fly?
Might be a bit heavy, but if you have a smooth place to take off, probably. Make sure it is not tailheavy!
Dacron is stretchy; the hi-tech fishing lines - so I hear - aren't as stretchy. Worth a try for more positive control.
Either Dacron or Spiderwire has the advantage that you can start with a short or long flying radius, without having to make up metal lines.
I'd try 25' to 30' lines at first. If 30' is too much, you'll likely be turning laps too fast to be comfortable on anything much shorter...
Luck!
greggles47 10-03-2007 07:14 PM
RE: will it fly?
G'day P51,
The Sig Buster suggests .10 as a minimum, but if you build lightly and make sure the balance point is in the correct point, I can't see why the .074 won't fly.
Steel lines are always preferrable but if not available, use what is.
Have you made contact with a CL group, or are you going it alone?
Regards
Greggles
p51drb 10-03-2007 07:46 PM
RE: will it fly?
thanks guys for the suggestions.i fly with my sons. there are not too many c/l flyers in my area.thanks
