Class II carrier
Hey all,
I've been out of carrier for couple of years and and just started a new Class II Skyraider. I'll be using a line slider and was wounding if I should use flaps in conjunction with the slider. Thx., Rick |
RE: Class II carrier
Not sure about your question.......but I've been looking for an excuse to get into carrier flying.........what manufacture did you get your model from??? Thanks [8D]
Hey guys,
Thanks for the PM's. STANG, I got the plans from MAN. Feb. 77, Ed Martinez design. It was org. for Class I but I blew them up 25% for the larger engine. If your intrested in a copy let me know and I'll get them to ya. AZ. a pretty good area for carrier from what I hear. Anyhow let me know. Rick |
ORIGINAL: Rick W Hey guys, Thanks for the PM's. STANG, I got the plans from MAN. Feb. 77, Ed Martinez design. It was org. for Class I but I blew them up 25% for the larger engine. If your intrested in a copy let me know and I'll get them to ya. AZ. a pretty good area for carrier from what I hear. Anyhow let me know. Rick make it so that it would be possible to have them stay up - then test fly it both ways. The slider probably doesn't really affect whether you use them or not - it's more of a flying style choice. So if you can give yourself a choice then go ahead. If it is not possible to engineer a method to disconnect, I'd probably opt to not include them - with a slider, you will probably be flying fully stalled most of the time anyway, and they don't add much at high angles of attack. Mike A |
| All times are GMT -8. The time now is 07:06 PM. |
