Recent vintage combat projects
1 Attachment(s)
For whatever reason, I've been on a tear building some old combat rigs, all scratch from plans.
A Classic "short tail" VooDoo, with a hard pressure tank and a ST G21 .46. Covered in silk, trimmed with tissue on the wing. The frame came out a couple of ounces heavier than I might have liked, but I had to beef up certain areas to handle the .46. With a 9x8 RevUp and 5% nitro stunt fuel, it was quite fast and flew as well as I remember any VooDoo ever flying. The Berryman Super Twister, also covered in silk. Trims are dope on this one. The intended motor is a rear rotor ST G40. The G40 is NOS and not quite broken in yet. I'm taking it slow with this one. It shows some real promise on a 75/25 FAI break in mix with an 8x8 APC. A Melvin Mathews Killer from plans published in AAM back in 1971. Just flew this one today and it was great (or as good as one can expect a low aspect ratio era combat plane to fly). It was pretty quick with a ST C.35 running my 5% nitro stunt mix I use on the Fox Stunt .35's. Clear covering is FasCal 500, red trim and tail are Ultracoat, the blue is epoxy paint. I've got a hankering to build a Scarinzi Super Satan next and maybe a Wooten Sneeker. |
RE: Recent vintage combat projects
Nice going but the sun wants to shine on them! Get them out of the shadows and into the sun!
Robert |
Hi partner, wonderful combat wings, very well made !! do you have the plans for them? Congratulations also by the classic Super Tigres !
thanks |
You might be able to find a Walter Umland kit for the Sweet-Sweep. A really neat looking combat airplane designed by the Grogan brothers of Fort Worth-Dallas area in the early 1950's.
Take a look here http://www.controllineplans.com/Images/sweetsweep.gif |
ORIGINAL: stg61abc Hi partner, wonderful combat wings, very well made !! do you have the plans for them? Congratulations also by the classic Super Tigres ! thanks I put another flight on the Killer a few days ago. This time I ran it on a straight 75/25 methanol/oil mix and it was about as fast as with the 5% nitro fuel. That particular C .35 has beastly compression. I don't remember if I upped it over stock or not. I fitted that engine back in the 70's. I do remember working on the crankshaft fit to loosen it a bit and did a bit of lapping with Lava. I may have eliminated any head gaskets and lapped the head right to the liner. |
| All times are GMT -8. The time now is 02:49 AM. |
