RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   Foam (https://www.rcuniverse.com/forum/control-lines-231/8970588-foam.html)
jayseas 07-28-2009 10:18 AM
Foam
What type of foam is used in hobby planes, and where can you find it, ie local stores and such?
thanks Jim
p51drb 07-28-2009 10:48 AM
RE: Foam
i have used foam poster board for some 1/2a planes works fine. seal edges with white glue.
jayseas 07-28-2009 11:00 AM
RE: Foam
Thanks for responding, but I'm looking more for thicker foam for leading edges and such.
rwlewis 07-28-2009 11:29 AM
RE: Foam
ummm....The two most popular foams used in hobby airplanes are:
EPS - Expanded PolyStryrene. This is the foam that drink cups are made from. Usually 0.75 to 1 lbs per cubic foot density is used in models. It can be purhcased in bulk from foam manufacturers (www.houstonfoam.com). It can also be bought in craft stores in sheets and blocks, but the lighter density stuff is less common. This foam is typically used in balsa sheeted wings, turtledecks, etc...This foam is reactive to some glues (CA, Styrene Resins, etc...) and solvents (acetone, gasoline, etc.). Hot wire cutting can be used to produce wings and other shapes.
EPP - Expanded PolyPropylene. This foam is much tougher, rubbery, and heavy and is often seen in electronics and appliance packaging. It can also be purchased from some foam manufacturers, but I have not found an easy source near me.....This foam is also more dense making it less suitable for some aspects of lightweight model construction. In models, it will often be used in these ultra-tough indestructible foamies or in combination with lighter EPS to toughen up certain areas. This foam is fairly inert and not affected by most common glues and solvent used in modelling.
Richard
Lou Crane 07-28-2009 11:34 AM
RE: Foam
Jayseas,
Most foam used for models is cut by hot wire from larger blocks, usually insulating polysterene stuff. Chain hardware stores may carry that in 1", 2" or thicker slabs up to about 4' by 8'. There are a few special foam materials that can be cut with knife or saw - and the smooth blue insulating foam often seen in house construction cuts and sands nicely (and can also be hot-wire cut.) More likely to find the blue foam at a homebuilding supplier than a hardware chain store.
The foam block materials come in different weights: Common styrofoam is around 1 lb per cu ft. The blue foam is around 3 lb/cu ft. The specialty hobby foam materials? Not sure... Styrofoam is about the least strong, but the shaped foam pieces are almost always sheathed in thin balsa sheet, other thin veneers or occasionally in fibreglas and carbon fiber "layups."
There are a few other plastic foam materials - like those used in meat trays - which you can see a lot about in RC Park Flyer topics in model magazines. I've never used it, but, for instance, AMA's current Model Aviation mag has an article on suitable adhesives for this stuff. It cuts with a sharp hobby knife, and possibly also with scissors...
Larger RC ARF models may include part of their structure (e.g., wings, tails) built around hot-wire cut foam...
You'd need some sort of a controllable transformer to get a length of wire to the just-right temperature to cut block styrofoam cleanly. That, and a few special tools, and good templates to follow, and some useful experience, and good ventilation (heated styrofoam fumes can be toxic), and some useful experience. The wire is usually held by a frame that keeps it stretched tight, and allow connecting to the transformer.
Hot-wire foam cutting is not something to dabble in for one use; it requires a bit of involvement and persistence to get best use of.
For CL, most foam has been used as a form to have thin sheet balsa glued to, to build wings and tails. A month or so ago, Flying Models mag had a very innovative article explaining how to shape the wing surface by gluing it onto foam, in a method strong enough that it didn't need the foam. So, the guy used the hot-wire INSIDE the sheeting, to CUT OUT most of the foam! The model in the example was a large stunter, so BELIEVE it had plenty of strength!
Are you starting to regret asking? :)
