RCU Forums
-   Control Lines (https://www.rcuniverse.com/forum/control-lines-231/)
-   -   Name the plane (https://www.rcuniverse.com/forum/control-lines-231/9227394-name-plane.html)
grotto2 12-21-2009 02:38 PM
RE: Name the plane
Is there any chance you could post a picture, supertiga?
I'd like to see a 50 year old one!
DaveSR71 12-21-2009 03:59 PM
RE: Name the plane
Will have to drag it out.
Tonight?
Have 8 mm film of it (me to) when it was new.
Good evidence of why dad had so much trouble with needle setting,,,he thought I was only flipping the prop:D
DaveSR71 12-21-2009 09:10 PM
RE: Name the plane
1 Attachment(s)
Poor thing is even uglier than I remember!
The abuse this airplane took when I was young is amazing.
Memory says it would stagger through outside 1/2 of lazy 8 and fly inverted for 1/2 lap or so.
The field probably looked like gophers lived in it after a day of flying.
BtnFlyGuy 12-21-2009 09:23 PM
RE: Name the plane
A little sanding, a snazzy paint job with some fine graphics and new wheels; you'd have a contender for a good looking ugly plane there. Imagine the satisfaction! Just remember, as I always say ... get pictures "before" that first test flight!
DaveSR71 12-21-2009 10:25 PM
RE: Name the plane
Just wouldn't be the same..............?
Actually I have thought about restoring it, just have not been able to come up with a legitimate reason to do so.
Might mess up the "patina" is what the wife would say. What ever that stuff is.
I think its dead and doesn't know it.
BtnFlyGuy 12-21-2009 11:45 PM
RE: Name the plane
I've seen worse than this restored, but those were full-size planes. As to "patina" that's the green on copper and brass that makes it look all old and such; supposed to make it worth more...In your case that's not patina, that's a severe case of hanger rash.
I'd suggest you offer it at auction (not EBay) with the stipulation that each step of the restoration be documented with pics and narrative. Sure would make a good article. Heck, I'm a writer by trade (though you can't tell by the vernacular I use here), send it to me postage due and I'll restore it and do the article. I'm DAV and could use another winter project, Heaven knows I have at least one engine that will fit since I have nearly a dozen.
Think it over...Justin
gcb 12-23-2009 08:48 AM
RE: Name the plane
ORIGINAL: supertiga
...Memory says it would stagger through outside 1/2 of lazy 8 and fly inverted for 1/2 lap or so.
Ain't no wonder... your stab and elevators are too small! :D :eek:
George
DaveSR71 12-23-2009 12:01 PM
RE: Name the plane
I thought something looked funny!
Will try bigger elevator next time.
Ok-so whats the green stuff on the wing?
BtnFlyGuy 12-23-2009 12:46 PM
RE: Name the plane
That weren't no mistake...thass a Alexander Lippisch/Jack Northrop attempt...
As to the green...maybe something Stephen King had a hand in?
gcb 12-23-2009 05:49 PM
RE: Name the plane
ORIGINAL: supertiga
...Ok-so whats the green stuff on the wing?
Since it is similar on both wings I would assume some type of trim scheme.
George
DaveSR71 12-24-2009 01:06 AM
RE: Name the plane
ORIGINAL: gcb
ORIGINAL: supertiga
George
Are you sure the elevator is to small?:D
grotto2 10-27-2014 09:38 AM
So far, four people have taken their first C/L flights on this plane. I hope to add to that number.
It's really strong and has survived some brutal treatment, including two figure nines.
If you'd like to build one, my tracings have been transferred to Visio and can be downloaded here:
http://www.mindspring.com/~rellis2/r...uillowsno3.zip
grotto2 08-02-2017 08:57 AM
Well I finally put the airplane shown in the original post heartlessly in the garbage can after scavenging it for parts.
It had a good run, with nine people by my count getting a first C/L flight on it. Ol' number 3 survived many attack by the inexperienced with uncountable figure nines and broken props as well as a second engine.
It was finally done in by a guy highly experienced decades ago, who didn't realize inverted flight and a flat-bottom airfoil was a bad mix.
But the trash-nobler has arrived to take it's place!
