blending fuels/nitro?
Need some answers, if i take one quart of fuel A, which is 25% nitro and all castor , and add in 10 oz of fuel B which is 15% nitro and a 20% castor synthetic blend.
? Is, after mixing these two fuel with numbers given, what will be the nitro content of the blend? |
RE: blending fuels/nitro?
Jayseas,
How many oz in a US Quart? - Imperial quarts are 20oz. |
A US quart is 32 oz. So the math goes like this, 32 oz (w/ 8 oz nitro) + 10 oz (w/ 1.5 oz nitro) = 42 oz (w/ 9.5 oz nitro), or 22.6% nitro. (That's 9.5 divided by 42 times 100).
The castor/synthetic numbers are irrelivant to the discussion of nitro content. Phil |
Thanks Philip,
You took the words outta my mouth, all I needed was the US quart size. |
[link=http://web2.murraystate.edu/andy.batts/ps/fuel.htm]Here is[/link] a fuel mixture calculator I wrote in Excel to mix two fuels with different nitro and oil levels and add extra castor if desired. It also allows you to specify the synthetic/castor blend. The calculator is designed to yield one quart of fuel.
I fly 1/2A and don't mix more than a quart at a time - I just got tired of doing the calculations by hand. andrew |
Thank you, fill kinda dumb now if i would have just put more thought into the matter.
Thanks Andrew for the info. Helpfull.
| All times are GMT -8. The time now is 05:26 PM. |
