Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 08-18-2003, 08:15 PM
Swat Cop
Swat Cop's Avatar
Default .
Old 08-18-2003, 08:17 PM
Swat Cop
Swat Cop's Avatar
Default .
Swat Cop
Swat Cop's Avatar
Default .
Old 08-18-2003, 08:18 PM
Swat Cop
Swat Cop's Avatar
Default .
Old 08-18-2003, 11:04 PM
BasinBum
Default Somehin Extra- Too Much Elevtor Deflection
Kevin you should use metal from where the pushrod exits the plane. They sell various lengths of 2-56 rod with the ends threaded.
Also, high rates are generally for slow speed flight and downlines are usually a good time to back off the throttle on aerobatic planes.
On my SE I found the stock control rod material to be very prone to temperature changes effecting it's length. Switch to Sullivan linkage that is less likely to need trim adjustments as the temperature changes. Read the package and it will tell you how much it is affected.
Old 08-18-2003, 11:10 PM
Swat Cop
Swat Cop's Avatar
Default Sig Somethin Extra
Right you are.
Old 08-18-2003, 11:54 PM
Katana
i am not surprised that is a lot of work for the servo with the plane going like 75mph
Old 08-31-2003, 08:25 PM
Buz_Bo
Kevin,
The way the kit goes together the pushrod slides down the tube and then you screw it in leaving the threads exposed at the end. this would have prevented what happened. Look at the instructions.
Old 08-31-2003, 09:47 PM
rcfireman
Kevin you are correct! I too have the Sig SE, and after looking at the picture I noticed the same thing you did. The metal portion of the pushrod should have been left to the length it was, and NOT cut! By cutting off the metal end just after the threads you are taken out the strength of the rod.
I have numerous flights on my SE (on HR) with No problems. It is a shame that you had to lose this aircraft to learn this lesson. I hope all goes well for you in the future.
Old 09-01-2003, 01:56 AM
Swat Cop
Swat Cop's Avatar
Default Somethin Extra
No, I didn't cut the metal pushrods thats the length they were from the factory. They may have changed them since I built mine. Mine was an ARF built around March. I know the ARF and kit are completely different (wings, wing tube ect) maybe the pushrods are different also that is if yours was a kit. Funny thing is I was planning on replacing the pushrods with all metal but never did. I didn't fly this plane much anymore. After flying larger models little 40-90 size planes are boaring to me.
Old 09-01-2003, 02:30 PM
Katana
why were you going full power on a 45 any way?
Old 09-01-2003, 04:09 PM
Swat Cop
Swat Cop's Avatar
Just to puzzle people like you.
Old 09-01-2003, 05:13 PM
Katana
your not puzzleing me going full throttle on a 45 i think its just dumb to do that let me know the reason when you figure it out
Old 09-01-2003, 06:01 PM
Swat Cop
Swat Cop's Avatar
Ok D*CK HEAD.
Old 09-01-2003, 06:12 PM
Katana
wow you went off
Old 09-04-2003, 08:51 PM
flytime56
flytime56's Avatar
well that's one of the first things i did when i bought this arf some years back, change thoes pushrods. I found they were way too weak, and would flex. after changing them i now have as much deflection as possible on both rudder and elevator. the rudder now comes close to the elevator, so now need to make some changes to have more deflection.
that's too bad that it happened to your plane. I love this plane and all the stuff that it can do.
GB
Old 09-08-2003, 02:46 PM
Bullitt
Default RE: Somehin Extra- Too Much Elevtor Deflection
I am building an SE ARF right now. Have the instructions and the parts sitting in front of me. There are two different sizes of threaded control rods that go onto each rudder and elevator pushrod. There are 1-1/4" rods that attach, with soldered links, to the elevator and rudder servos. There are 3-1/2" ones go on the control surface end of the push rod. You slide them into the pushrods, non threaded ends first, then thread them into the ends of rod. Then you thread a plastic link to it and attach it to the control horns on the elevator and the rudder. The 3", or so, of the control rod that is inside the pushrod keep the pushrod from flexing outside of the model. From the picture it looks as if one of the 1-1/4" control rods made it onto the wrong end of the pushrod, where the 3-1/2" rod should be to prevent the flexing. Hard to tell from the photo, but it sure looks like it.
Old 09-09-2003, 10:19 PM
randy41
Something was installed wrong. I built my extra for a kit and it wasnt that away.
the control rods are long enough to screw into the plastic pushrod and keep that
from happening. I got a FA 56 saito on mine and i have put this plane through
3D hell and back and not had that problem on high rates and then some.
Old 09-11-2003, 05:28 PM
RONSTERMONSTER
Full up elevator at hight speed on high rate would cause a high speed stall . The crash could have broken the supports for the nirods allowing it to flex inside the fuze of the plane
Ron
Old 09-11-2003, 05:38 PM
I Got Hit
I Got Hit's Avatar
I personally dont like and dont use nylon push rods. Just dont trust them and have seen things like that happening before. In addition, if you are concerned with precision, the expand slightly in hot days.
Old 09-11-2003, 08:25 PM
Skycam41
Skycam41's Avatar
Correct me If I am wrong but with those huge control surfaces I do not think this plane was designed for 3D and general aerobatics rather than a flat out speed demon.
Cheers
Mike
Old 09-12-2003, 03:04 PM
diehard
My Feedback: (18)
Obviously a problem with the assembly of the push-rods Who would ever believe that the plastic inner tube without the support of the metal rod can move a control surface anyway?
Old 09-12-2003, 06:42 PM
Katana
Okay maybe they didnt use good hardware. But flying on a 45 at full throttle is dumb. its like trying to use airlerons to taxi.
Old 09-12-2003, 07:22 PM
mutare23
I would think that people can fly their planes however they like and enjoy it.
I have a couple of quickie 500s for the sole purpose of flying flat out and low enjoying the 'balls to the wall' feeling. I would never risk my pattern babies doing this.
Perhaps the lesson, albeit costly here, is that the better the control linkages then the better the performance of the ependages on the end of those rods.
I bet Kevin will ensure that for the rest of his modelling time his control linkages will be all but nuclear proof and good luck to him to.
Cheers
Phil
