Rebuild and modification of a 15 year old ARF
Pete
I did not get much done last week. So many things seemed to eat my building time. Did a lot of research and just thinking about options. Also visualizing steps and the exact sequence I need to do things in.
The wife and I spent several hours measuring for the different pieces of material to do the wing, fuse and tail feathers plus all the control surfaces, fuel tank hatch. Trying to figure out the exact sequence to cover the wing (to have minimum seams showing or at least be hid) made our heads hurt. Can't say the fuse was much easier. But now I have a exact plan.
So set up the card table to cut fabric on. I am basically going to make a covering kit.
I guess I will go Thur much of the same process with the fiber glass for the cowl.
I use a rotary knife to cut cloth with (both fabric and glass).
I spray hairspray on the material were I intend to cut. I also use 2 pieces of paper on about a 1/4" either side of my cut line. This keeps the material from fraying , but the downside is it also makes it a little stiff, thus the narrow strip of hairspray.
I think I will use water thinned Titebond to tack the fabric down, Then take the card table outside to the porch area when there is some breeze or light wind and use nitrate dope to seal every thing down. That keeps smell outside and hopefully will not affect my asthma. Then I can shrink the fabric by misting with hot water, and my covering iron and hot air gun. Then 1 light coat of nitrate dope to further shrink the fabric.
Well at least this is my plan, lets see if it works.
This is very tedious work.
Continuing to cover, concentrating on the wing. The tips are a PITA.
Starting to get ready to fiber glass the cowl mold. I realized after the mold was don that I should have put a piece of ply on the back of it were the screws hold it to the fire wall. I had just ran sheet rock screws through the motor mount bolt holes into the foam. Way to soft for that. You really need very solid anchor points. Insert some ply were the screws go. So I put a fat lag screw through the big (1") hole for the fuel plumbing into the foam. That's got her down tight.
The fit between the mold and fuse could have been better so I filled the joint with light spackling and sanded for a perfect match.
Next step, I ran a piece of fabric about 2 inches wide around the fuse exactly at the fire wall mold junction. I did not want to chance that the glass cowl was a tad smaller than the fuse and the fuse is going to be fabric covered. That piece of fabric is not doped down or attached in any way.
After the fabric I have ran a 2" strip of packing tape. This is just plain scotch tape. It will be waxed so I have some chance of parting the glass cowl from the fuse.
Unable to upload pics at this time
I worked on the glass cowl doing as I last posted. The fiber glass I am using is 4.25 ounce Four Harness Satin (Crowfoot).
http://www.fiberglasswarehouse.com/weave2.php see 3rd paragraph
Very pliable and follows curves great. From my understanding of the thread configuration it should provide a great deal of torsional rigidity. not really necacary for a cowl but great for a wing. I originally bought it for vacuum bagging foam/glass glider wings.
I cut multiple pieces of cloth and laid the on the mold smoothing and stretching as I went. I used a mist coat of Scotch Super 77 contact spray adhesive to hold the glass fabric to the foam and for the successive layers of fabric. Lay the cloth down in swatches that are not to big to manage and add more in over lapping patterns. I made sure to get each and every on as smooth and even as possible before adding next fabric swatch.
After I had put on three layers of cloth (a little more in areas because of overlapping) I started applying the finishing resin, using an acid brush to spread it on. I also tried to work the resin in by additionally brushing what was already there and pushing (stabbing motion? poking?). I also used a plastic spreader to help work the resin in.
The fabric became more translucent as I worked the resin.
Still there are some areas were it is not as translucent and I wonder if maybe I did not get those areas whetted out sufficiently?
I had my wife take pics while I was doing the glass work so as to demonstrate how I did this job.
Man O Man I sure hope I can get the cowl off the fuse when it is dry.[sm=drowning.gif] I will cut a parting line about 3/4 inch behind the fire wall.
Wife said 9/16. Tried that and it is 9/16s. Boy is she smart.
What a relieve.
I had two layers of covering fabric (polyester dress lining) wrapped around the front from the fire wall back about 3". Grapped a corner of 1 layer and started tugging,. Took a lot of force but it started to slide, so I just kept working my way around and around till I had it all out. Then I did the same thing with the scotch tape. Only some of it came out. I gave the cowl a couple of open handed slaps (gentle) around it, then grapped it and pulled. WOW it just popped off. WAY COOL
Parted the tank hatch and removed the rest of the tape.
I HAVE A COWL
It slides on nice and easy.
Also I need to clean the inside a little better.
I will mount the cowl to the fuse with some real small button head Allen screws
Thanks Oberst. Do you have a current build going?
I spray hairspray on the material were I intend to cut. I also use 2 pieces of paper on about a 1/4'' either side of my cut line. This keeps the material from fraying , but the downside is it also makes it a little stiff, thus the narrow strip of hairspray.
I've been posting a few pics, but I've been keeping most of the build under wraps because this is experimental. I'm not sure if it will work, even though I think I can make it work if you know what I mean.
The first few pictures is this plane I'm rebuilding before the crash. The later photo's is what It looks like now. I'm making it a " What If " Luftwaffe 46.
http://www.rcgroups.com/forums/showthread.php?t=1413244
It's good to watch how you did the fiberglass cowl. I heard about how you make it, but to see the pictures on how it's done makes a big difference. Fantastic job! And thank you!
Pete
Made some mistakes that I will not make next time.
#1 Got to thin the resin out good so it really penetrates and wets out the fabric. I will be doing some experiments on some throw away dummy parts.
#2 See #1
Not yet satisfied with the inside of the cowl much less with outside. It aint got to be perfect but I sure don't mind if it at least looks like it is. Will strive for that.
Down the road for this bird are wheel pants and FLOATS. When I first acquired this plane I had a kit for wooded floats given to me. I thought they were a bit heavy and the extra fiber glass landing gear strut only compounded that. But the plane just did not seem to notice although I made sure to keep it a little hotter than normal on landing. I had added a sub fin to the bottom and that kept it well behaved in yaw. I had a total blast flying off of water. Now the vertical stabilizer area is significantly greater and taller, so I hope that is all it will take.
I will look and see if they are suitable wheel pants (for not much $), or I will just build some. I have been brain storming them already.
Floats and struts I am definitely going to craft myself. Aluminum struts. And fiber glassed foam floats.
Still a lot to do on this plane.
I can definitely see places were I did not get proper wet out of the fiber glass fabric with resin.
and once again the site is having technical problems, can't post pics.
I intend to put 1 layer of glass on the inside of the cowl starting from the fire wall line forward. I WILL USE THINNED RESIN LIBERALLY. That I hope will get the areas that did not get whetted out right the first time. Then I will seal the inside with non thinned resin to avoid any oil soaking or penetrating.
I have opened up the nose ply ring and chamfered it.
more pics to post but not till the site is working correct. seeing references all over the site about that.
I will post an addendum on experiences on making a glass cowl a little later. Sort of a lessons learned, adding a " kind of should have done " to it.
Next cowl (oh yeah there will be more) will use a balloon over the lay up, should produce a much better outer finish.
do you think glazing putty would work for smoothing the finish? i have a couple of ubes
When you inflate the balloon ( get 1 that is pretty good size ) lard it up or wax it (Carnuba works good several waxings needed and barely wipe off the last coat) or spray with silicon mold release. As you press the balloon over the lay up let the air out as you go. balloon should just pop right off when the resin is dry.
I quess this would be sort of a poor mans vacuum bag. I have done that for glider wings, but they are not all compound curves. But the balloon will do compound curves nicely.
still can't post pics
By the way here are a couple of pictures of my last rebuild. I crashed my son's airplane, a scratch built form plans Kadet JR. O.S. .25 for power. Tried to force it off of grass and did not have the needed airspeed. Tipped stalled violently and DESTROYED the fuse. The wing and tail feather suffered nothing more than getting dirt and grass on them. So I made a new fuse and wooden cowl. Kept the original paint scheme. I finished that rebuild this past January and then started this current project.
Darn, I do not have any pics of him with the airplane.Nuts still can't post pics
I started sanding with a sanding block that has a foam pad on it I think I have either 180 sandpaper on the block. coarser would cut faster, but leave deeper scratches and maybe cut some glass threads. Patience and elbow grease is the order of the day here. Thankfully it sands pretty quick. It is very easy to see were more sanding is needed as those spots remain shining. I do have some small bumps to sand down and some places were the top layer of glass has a bubble in it. The fabric lifted above the underlying layer of cloth forming a bubble, may also have entrapped an air pocket when I applied the resin. Again using a balloon would have eliminated this problem and I would have a lot less sanding to do. I also think the cowl would ultimately weigh less. SO it is sand. sand, sand and more sanding. It is leveling out fairly quick. I am taking it almost down to the glass. A few spots are low but very small, so I will smear some thinned out resin on with my finger.
Will post pics when the site is working for that again.
At any rate I want to learn how, as that is how I intend to make my wheel pants.
Bad news, I had a heavy shelf fall on the Neptune Amphibian. The plane is totally destroyed. I'm not going to even attempt to try to fix it. It's beyond repair and I've spent enough cash and time on it already. Plus they still make the original Neptune and I can always get another one for $100. Bumber!
Pete
It's getting there!!!!
Pete
Oh I did catch a foam glass wing in a garrage door once. Garbage can stuffer.
