Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
Plane way nose heavy
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 04-29-2015, 02:49 PM
Snowball1952
My Feedback: (22)
Angry Plane way nose heavy
I HAVE A MIDWING PLANE THAT SOME ONE BUILT MANY YEARS AGO. WING SPAN 83 1/2",WING CHORD 15 1/2" FUSALUGE IS 60". MY PROBLEM IS I HAVE TO ADD 2 POUNDS 11 OZ TO GET IT TO BALANCE. IT HAS A MAGNUM 91 4 STROKE. IT WEIGHS 9 LBS 14 OZS WITH OUT THE ADDED WEIGHT. I HAVE BUILT AND FLOWN MANY PLANES AND NEVER HAD THIS SITUATION SO FAR OFF. ANY HELP WOULD BE GREATLY APPRECIATED. I CAN POST PICS IF YOU LIKE!!
ID:	2093116   Click image for larger version
ID:	2093117   Click image for larger version
Old 04-29-2015, 03:45 PM
flyinwalenda
flyinwalenda's Avatar
What engine is in it?
Old 04-29-2015, 03:55 PM
Snowball1952
My Feedback: (22)
Yes I should have put that in,sorry. It has a Magnum 91 4stroke. By the way the plane weighs 9 lbs 14 ozs with out the added weight.
Old 04-29-2015, 04:57 PM
flyinwalenda
Maybe it has an extra long nose ?
Anyone would be guessing without seeing detailed pictures and knowing how you balanced it and using what measurement.
Old 04-29-2015, 07:26 PM
foodstick
foodstick's Avatar
Can you move your receiver battery ALL the way back?, Mount the servos in the tail? and then use a really heavy tail wheel? I wouldn't be afraid to move the firewall back either...
Old 04-30-2015, 04:21 AM
Snowball1952
My Feedback: (22)
The whole thing I don't get is that it was flown by the father this way years ago. I just don't see how.
Old 04-30-2015, 07:04 AM
Villa
Villa's Avatar
Hi Snowball 1952
Try this for the CG and report your findings: Measure from the leading edge of the wing to the trailing edge of the ailerons. Divide that figure by 4. Take that result and measure back from the leading edge of the wing for the location of the CG.
Old 04-30-2015, 03:34 PM
Snowball1952
My Feedback: (22)
thanks i will try it and let you know. Thanks
Old 04-30-2015, 04:08 PM
Snowball1952
My Feedback: (22)
Thanks it is pretty good and gives me a comfortable place to start. I won't be afraid to try now that I have a good place to start. Grateful!!!!
Old 05-01-2015, 07:43 AM
mattnew
I'm confused by the pictures.....can you clarify some things?
- It looks like you are using a vanessa?
- with the junk on the elevator stab it looks like you are balancing at the rearmost spot on the wing, right behind the cockpit?
if those are both true:
- that balance point seems very far back, too far back ( currently tail heavy not nose heavy ) ... where does it balance without the stuff on the elevator? I'd expect it someplace about the center spar on the wing.
Old 05-01-2015, 08:44 AM
MTK
I agree with Matthew if the plumbbob is located properly, the balance is way too far back. An earlier poster mentioned a good starting place for this model...1/4 of the chord starting at the wing LE and moving to the TE, is a good place for most any plane with rectangular wing.
Old 05-02-2015, 12:31 PM
Snowball1952
My Feedback: (22)
Thanks guys i think we got it worked out. I while let you know!!!!!!
