Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
P-51 Mustang deadstick, stall and crash
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 02-12-2020, 05:43 AM
DominicM
DominicM's Avatar
Default P-51 Mustang deadstick, stall and crash
It happens even to the best pilots.
jnayjaso (04-05-2020)
Old 02-12-2020, 11:50 AM
BalsaGhost
Engine failed as he was putting in flaps. That stinks!
Keep it clean and level and a slow controlled landing into almost anything is better than a stall and crash.
Old 03-28-2020, 05:04 PM
66carsandguitars
He could have save this had he put flaps up and drop the nose to get airspeed up. He had the altiude.
Old 05-04-2020, 10:12 AM
scottrc
scottrc's Avatar
I did the exact same thing with my TF P-51 on one of my early flights with it. When the engine quit on final, I had full flaps and didn't raise them to decrease my decent. The decent rate tripled and I ended up in the ditch about 20 yards from the runway with one of the landing gear knocked through the wing.
Old 05-08-2020, 10:30 PM
jonesg2
Yrs ago I had an Ikon Nwest supercub with flaps, it allowed for rather steep landing approach, I wouldn't bother if doing a flat approach.
Old 06-10-2020, 04:16 AM
Fidd88
Bad luck! As an ex-glider pilot I only use flaps very late in the approach when flying powered aircraft, when I'm certain of "getting in". It's a completely different psychology, viewing a running-engine as a "bonus" rather than "as of right". Mind you, there are other potential issues with very late selection of flap - it does give one a lot of pitch and trim changes to contend with on short-finals, but it does confer some security for the evil-day when the prop stops! (I speak from experience on full-size rather than RC aircraft).
Old 10-12-2020, 09:19 AM
isoexcite
Man, that is a shame! I dread the day it happens to me!
Old 12-28-2020, 08:24 PM
dannoh
dannoh's Avatar
Wow, sorry about the crash. I have lost several, including an AT6 that about the same size.
I won't fly a plane im not willing to lose. Good sign seeing it moved off the field in one piece. Good luck with the repair!
Old 12-30-2020, 03:26 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
The wind definitely made the situation worse,, But he put himself in a no man's land situation for sure,, why set up for your landing so low and slow on the down wind leg in windy conditions?
Old 04-01-2021, 09:28 AM
donnyman
donnyman's Avatar
posts 3 said it right ................ raise the flaps drop the nose,keep the airspeed up. I will also try to remember that.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
