Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
multiplex cularis
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
multiplex cularis
Old 05-08-2020, 12:50 PM
bmxbumpkin
Unhappy multiplex cularis
Hello ya'all,
First time poster here i believe, although i have been a member for a while now. I was flying my Multiplex Cularis yesterday, and quite a ways off I saw my prop and spinner go flying off. Does anybody know of a replacement spinner for it?
They are discontinued everywhere. I found some information on the size of spinnerThis is the Prop Driver for the Cularis EP ARF Glider from Multiplex
FEATURES: White in color
Sturdy plastic construction
INCLUDES: One 2.2" (55mm) spinner
All hardware for mounting
REQUIRES: Installation
SPECS: Length: Tip to backplate 2" (50.8)
Diameter: At backplate 2.25" (57.1)
Multiplex
Part MPUM733183
I have an extra set of blades. Any info would be great!
Thanks so much,
Lucas Chapman
Old 05-08-2020, 06:01 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
The easiest and best thing to do is go with an aftermarket spinner. You just need to select one of the correct diameter and that fits the correct size motor shaft. You can also upgrade from the stock prop as well. The Aeronaut Cam props are a great value.
https://alofthobbies.com/power/spinn...ing-props.html
https://alofthobbies.com/power/props...lders.html?p=1
bmxbumpkin (05-08-2020)
