Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
Need prop and gear hardware - can’t find
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 02-19-2021, 01:49 PM
chevyv8
Default Need prop and gear hardware - can’t find
Ok fliers, I have an airfield 1450mm p51 that was given to me a present probably 5 years ago (I think)
It is a 6 channel version with retractable gear and all other surface controls
Yesterday, during initial taxi, all was fine. I lined up and began to get into the throttle. I had to input some rudder to keep it straight, then the left side gear collapsed prior to take off.
I still need to inspect the gear to see if it’s something I can repair or if I need to replace it, but the individual props (all 4) are now broken.
Heres my problem-this plane may have been discontinued. Everywhere I look for “airfield” parts, is out of stock with no return mentioned.
Is there another make/model where the gear and ESPECIALLY the props are interchangeable?? I personally don’t care about the wheel pants or doors right now. They don’t make the plane fly or roll.
If I need to replace the spinner base to install a different style blade, that’s fine, but I can’t find dimensions for other versions/makes/models such as FMS etc
Any help in this would greatly appreciated
Old 02-26-2021, 06:42 AM
jester_s1
Moderator
The prop shouldn't be hard to manage. If you have to switch to a 3 blade, go up one inch in diameter.
Eflite has electric retracts that may require drilling new holes for mounting. I'd definitely replace both if I were you.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
