Loose retract ??
FL
Previous flight didn’t go well. Tipped over with the gear still out. None collapsed or destroyed, 1 is loose.
I’ve taken it apart to try and figure out if I can tighten it but no luck.
it moves at the trunion(?) - cross bar / metal bottom. The threaded rod looks good and doesn’t move unless the motor moves. It does go up and down without fail, I’m just concerned about the next landing and it collapsing causing further damage.
any thoughts ???
thanks in advance
any thoughts ???
thanks in advance
