Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
(Look below)Is this plane above you and going away or below you and coming toward?
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
View Poll Results: A poll
Above and away
31.51%
Below and toward
68.49%
Voters: 73. You may not vote on this poll
Old 11-18-2004, 07:49 AM
cliffclof
cliffclof's Avatar
Default (Look below)Is this plane above you and going away or below you and coming toward?
I thought of this after seeing the video disscussion in this crash post.
Giant B-52 Destroyed
http://www.rcuniverse.com/forum/m_21...mpage_1/tm.htm
ID:	194026   Click image for larger version
Old 11-18-2004, 08:12 AM
cwrr5
My Feedback: (32)
cwrr5's Avatar
Default RE: (Look below)Is this plane above you and going away or below you and coming toward?
I'm an optimist - above and away
Old 11-18-2004, 08:27 AM
exeter_acres
exeter_acres's Avatar
I won't answer until I give it a little up elevator
Old 11-18-2004, 08:58 AM
volkan
I hope its not coming towards me
Old 11-18-2004, 09:11 AM
Sokhar
inverted and heading for the ground (hmm I think alot of crashes start that way LOL
Old 11-18-2004, 09:30 AM
StallN
I'm like exeter, but I would give some right aileron unless, of course, you don't have ailerons. I've been there before. Rocking the wings is how I recovered.
Later
S
Old 11-18-2004, 09:55 AM
Muxje
Muxje's Avatar
Below and Towards! How else would you be able to see the entire vertical stab?
Old 11-18-2004, 10:13 AM
Kevgofly
Kevgofly's Avatar
Muxje,
That doesn't work because you can also see the entire horizontal stab. Gotta do something to figure it out, my vote is wing rock. This is why a trim scheme is so vital. New AMA rule, all B-52's must have red and yellow sunburst on top, NASA test pattern on bottom.
Kev
Old 11-18-2004, 10:28 AM
Kevgofly
Kevgofly's Avatar
Survey says,
Old 11-18-2004, 10:32 AM
cwrr5
My Feedback: (32)
cwrr5's Avatar
For some reason I don't think the USAF would go for that color scheme..........
Old 11-18-2004, 10:43 AM
Kraut
Both drawings could be doing either - going above and away, or below and towards. They need some way of differentiating between the top and bottom. The poll needs one more selection - either.
Old 11-18-2004, 11:53 AM
MHawker
My Feedback: (16)
MHawker's Avatar
I fly standing on the ground, so it HAS to be above me........ unless I just crashed.
Old 11-18-2004, 12:29 PM
TOPGUNNER
TOPGUNNER's Avatar
is my size 12 heading for your _ _ _ or already in it..?????
Old 11-18-2004, 01:09 PM
cwrr5
My Feedback: (32)
cwrr5's Avatar
1st one Above and away, 2nd one is down and towards. First one has transparent covering!
Old 11-18-2004, 01:28 PM
Flyboy Dave
My Feedback: (21)
Flyboy Dave's Avatar
Yes....the plane can't be below you....
....unless you are standing on top of a hill. (it's coming towards you )
FBD.
Old 11-18-2004, 02:24 PM
TerryE
My Feedback: (12)
TerryE's Avatar
Maybe you are a REALLY good flyer and have jumped over the plane when it is flying between your legs
Old 11-18-2004, 02:25 PM
cliffclof
cliffclof's Avatar
I think optical illusions cause a few crashes. I think dayglow orange on one panel helps me, but I'm new.
When I drew it I was imagining it coming toward and looking down, but I was trying to think non-bias. Or draw it that way. I think a lot of people see different things and I wanted to find out.
Also if it is looking down and toward I think I might be on the runway about to taxi by, but I like the hillidea because the design on the plane needs to be destroyed. Running it into a mountain will definatley solve the problems with this illusive plane.
Check these pictures out.
ID:	194144   Click image for larger version
ID:	194145   Click image for larger version
ID:	194146   Click image for larger version
Old 11-18-2004, 09:33 PM
daveopam
My Feedback: (9)
daveopam's Avatar
That's why I don't have a plane with retracts.
david
Old 11-25-2004, 02:48 PM
suitcase
suitcase's Avatar
My .02: Obviously flying from the ground. Third from the left is flying upright and away. The other three, regardless of the wing tip color are in a steep right bank and headed for the ground. If they aren't, then the horizontal stab is twisted 90* and has become the vertical stab. That's what it looks like to me.
Old 12-03-2004, 11:40 PM
SkyDude
SkyDude's Avatar
It's right in front of me and doesn't move, except when I move the scroll bars, then it just goes up and down.
Old 12-03-2004, 11:45 PM
antslake
antslake's Avatar
that is why we hover now
