Need help with removing hinges
My Feedback: (35)
RE: Need help with removing hinges
So I'm assuming you just cut them off as close to the wood as possible? The person that installed these put all the control surfaces VERY close together almost to the point that the wood is binding during movement, what do you usually use to cut the old hinges?
I've removed them without too much difficulty. Remove the control surface by cutting the heads off the pins. Now with access to the hinge, cut the glue joint on each side with a #11 exacto. The task is easier if recovering because heat can be used to release the epoxy.
