Best method to remove old EconoKote film?
Well, like the subject says, I am looking for the best way to remove some old Econokote from a skinned wing. I am pretty sure this film is the low temp variety.
I want to remove this stuff, it is old and saggy. I plan to glass the skins and need to get all the old stuff off. I started to just pull it back and the clear part of the film started to separate leaving the color stuck to the skin, so I tried briefly to apply heat but it did not seem to help. Help. Peace, Wolf |
RE: Best method to remove old EconoKote film?
The only workable method I have been able to find is an "Old Milwaukee" paint striping heat gun!! Put it on high...turns the covering into a gooey mess, then scrape it off with a razor knife!!!:D
GOOD LUCK |
I will try a little heat again, but it looks like sanding is the common method.
Peace, Wolf |
I find that the easiest method to remove any kind of film
covering is with my Top Flite heat gun, find a seam or corner hit it breifly with the heat, grab the edge of the film and heat as you pull up at a 90 degree angle, leaves very little residue. To remove any remaining residue, use a putty knife to gently scape as you apply heat from heat gun. I have used this method on all brands of plastic coverings with great sucess. Bill D. |
